7
Everything posted by PathyAndTheJets
worst oil filter location EVER!
PathyAndTheJets replied to BendRed's topic in 90-95 WD21 Pathfinders
It's like 3.8quarts with a filter change. I just dump my gallon of Rotella in there and call it good. I thought it was interesting that in the owners manual it tells you to change the filter every other oil change. *at least on my 88 it does. -
I remember the Toyota 3vze (3. Slow) having the tiniest little filter ever. Like two inches tall and like 3 in diameter. -
IIRC, Nissan calls for Pennzoil 80w90 LSD. Any 80w90 with limited slip additives should be fine. You can also just use 80w90 and add a tube of LSD additive. Ask about fluid for a "posi" rear end. They're probably Chevy guys and call all limited slips Positraction. If it's leaking out the fill plug it's over full. It's good practice to use a thread sealing tape or compound on your plugs. If using tape, be sure to get oil resistant type, and wrap it opposite of the way the plug tightens, i.e. wrap the threads counter clockwise since the plug tightens clockwise. That way the tape doesn't just unravel when the plug is installed.
PathyAndTheJets replied to RedRider3141's topic in The Garage
Got my spoiler and third brake light installed. -
In my experience, the four doors seem to have more problems with frame rust. 3 two doors with nice, solid frames and one 95 with a nice hole on both sides. Maybe because the rust ate out all of the poorly maintained two doors... I think the 2 doors look better, and I'll just swap in a fuel rail and ECM from a 300ZX or a later pathfinder into it. I'm okay with changing the timing belt @60k.
I finished soldering up my headlight upgrade harness, and installed it. Ended up with a lazy eye, relocated a ground and got both lights shining bright. Can't wait to see the difference tonight. -
Picked up a new 4wd switch from Nissan today. Got it installed, and now a have that nice green light. Probably a waste of 35 bucks... but I can't stand broken stuff. -
Engine conversion/replacement opinions and advice.
PathyAndTheJets replied to burgundypathy's topic in The Garage
If the transmission is the same besides the bellhousing, you can swap that over to fit. Super common trick for the earlier fs5w71 transmissions so you could get the better gear ratios out of z cars. You should be able to use what you've got on a VG, if you used the factory manifolds on the z24 then that carb should just bolt up. Or was the z24 still carbed in Australia? Then you may need an adaptor plate fabricated if they changed the intake manifold between the carbed and fuel injected z24s. -
Replaced my cardboard battery mounting spacer with shorter j bolts. Looks better -
No spark after replacing plugs, points and coil... Any ideas?
PathyAndTheJets replied to taylorhayis's topic in The Garage
Need more engine pics. That looks like an L-series dizzy to me. I have a hard time believing that is factory, I don't know why they'd use an inferior ignition system on it. Overseas got fuel injection and turbos before the US market. But he got points at his parts store, which means they have it in their systems. I'm baffled. I think the coil gets power when the points are closed. Then it transforms it and sends it to the rotor, wires, plugs, and then ground. -
I thought all z24s were with 8 plugs not 4. The z20 and z18s were the only ones with 4 plugs IIRC. And like I said, I've never seen a Datsun or Nissan motor after 76 with points. -
Points? Sure enough, points and condenser. That doesn't have HEI? Nissan did away with points in 1976 in the states. -
I gave her a good washing and then decided to bed line my skid plate since I had it off to replace the starter. -
88 Pathfinder XE 262,000 miles, original engine and tranny.
All MileMarker Hub Owners, specifically #435 for 1990-2000
PathyAndTheJets replied to Precise1's topic in The Garage
IIRC they tell you not to pack them with grease. I imagine a light coating of wheel bearing grease wouldn't hurt anything. Perhaps the plastic they use is sensitive to petroleum grease? Maybe a silicone brake grease would be better. Drop the metal parts in evapo rust for a afternoon. Should clean them right up. -
Painted the bumper today. Probably will do the rear when I can get it off to straighten it out better.
Put on a new exhaust preheater hose. Got a optima for it, but the j bolts are too long. Temporary fix until I can find the right length. Got my decal put on! Thanks fleurys!
Picked up a replacement for 50 bucks. The other side got sanded, the rust pitting filled and painted with the closest paint I could find. Is that an original alternator I see? Not sure if I should be concerned or impressed. Original radiator hoses?! Engine shots
Figured it was time to get out of the new people section. I bought my Pathfinder in June for 500 bucks. It had 260k on it, 4 bald tires, and wouldn't idle. She looked like this. The first order of business was to replace the throttle body. Probably could have cleaned it, but as a proper Nissan enthusiast, there was a new one sitting on the shelf. I also pulled off that stupid dirt catching trim. Got it running well, and put decent rubber under it. Got new sway bar links and shocks all around. After the mechanicals were taken care of, it was time to replace the Swiss cheese fender and fix the rust on the other.
http://community.ratsun.net/topic/55183-yellow-high-beam-tint/page-1
If you want yellow, you'll probably want to use some glass paint. There's probably several write ups for the high beams on older BMWs and such.
A new for me type of charging system problem. Very Odd
PathyAndTheJets replied to StevenT73's topic in General Forums
Definitely sounds like a voltage reg. It really should never go above 15 to 15.5v. You'll need a new alternator. I don't hear great things about remanufactured ones, so I'd get a used one or new if you can. -
Beat my bumper back into shape, and did a little cleaning. -
I probably could've gotten it closer. But my ears were ringing and my arms were tired. I doubt I could've gotten much better without removing the bumper anyways. Good enough for me, for now.
Felt motivated after work today. Had to do something about the bumped bumper. So after wailing on it for about twenty minutes I got it here After some more refined beating I ended up here.
