10
Everything posted by Terranovation
I drilled and tapped into my carrier holes to put grease fittings in, unfortunately it doesn't close with the fittings in place so I could only install the fitting, grease it then remove. Repeat for the bottom joint. I found a couple of small rubber plugs to seal up the holes until next time.
For me the violent shaking was worn out control arm bushings, both upper and lower. Check all rubbers under the front and also the rear bushings. Myine was so bad you'd get up to 55 mph and the steering wheel would vibrate out of your hands like you would literally have to hang on for dear life.
I'm concerned that you are using flamey stuff around wood logs lol. Anyway, good job looks like it will survive.
My guess is they are loose and not connected to the + terminal properly. That was the issue with mine, the wires were just jammed in there so I crimped sone ring connectors on the ends of the wire then attached them to the through bolt on the + terminal.
Speedo jumps in park, no first gear.
Terranovation replied to windcalmer's topic in 90-95 WD21 Pathfinders
Is the switch for the transmission switched to the 'hold' position? If so, the transmission will be taking off in 2nd gear, not 1st. Make sure the switch is in the middle 'automatic' position. If so, then the switch is bad and needs investigation. You can pop it out from the dash using a flathead screwdriver with a bit of electrical tape on the end so you don't gouge your plastic. -
Terranovation replied to RedRider3141's topic in The Garage
Replaced blown stereo fuse which involved pulling the whole thing out because the tiny 10a fuse is on the back of the stereo and it's impossible to get my fat hand in there. Screwed everything back in then wondered why I wasn't getting any stations. Ohh, forgot to connect the aerial plug lol *unscrews everything again* -
Toilet paper. Lots and lots of toilet paper.
Headlights go out when I turn right -_-
Terranovation replied to kev9180's topic in 90-95 WD21 Pathfinders
Oh well, time to go to your local auto store and get a new battery hold down clamp. The kit comes with the clamp and two metal rods with the screw connectors on the ends. The other end of the rod has a hook where it should loop into a hole down either side of the battery stand. They are only like $10. -
No worries and remember to disconnect negative terminal before playing with wires.
After becoming stranded on a freeway on ramp with a blown fusible link, I rewired it by installing some metal loop connectors and attached it via the tightening nut on the + terminal. Cleaned everything up with CLR and taped up any exposed wiring. Reverse safety switch fuse had blown to so new 10a fuse and she's working again. -
Sounds like you need to check the internals of that indicator/light assembly switch. Inside there are brass contacts that when you turn the lights on, the brass 'finger' will close making contact with the small magnet underneath. So undo your plastic steering wheel column again, remove the two screws holding the switch assembly and unplug from the ignition. Take off the plastic cover of the switch by prying off with a small screwdriver. From memory there are tiny plastic clips which hold it on and they have a tendency to go flying into the great unknown. Don't panic if you lose the cover though. Mine has been running quite comfortably without it. Inspect the ignition connector pins for any damage. Inspect the brass fingers for any damage. Get some fine grade sandpaper and clean the contacts underneath each brass finger. From the sounds of it, the indicator brass finger is coming into contact with one headlight brass finger, so you are getting a power crossover. I'd fix this soon before it melts your ignition switch or something. -
All fixed, it was just a blown fuse. Found in the fuse compartment next to drivers seat, bottom row 2nd from the right, 10a red fuse. Phew lucky I didn't have a burnt control module! I've seen it's happened to a few other owners. Reverse is working again!
Aha yes when you press the brake pedal, there should be a click noise as the P is disengaged, I will look into that. So the switch should be somewhere near the brake pedal.
Should be right next to your + battery terminal connected to there.
Went to reverse and gear stick wouldn't budge. Had to push safety switch next to the gear lever down to get it to reverse, which it does. This is an auto trans and fluid is clean, is there a way of resetting the safety switch?
I placed tweeters up above rear windows, the roof molding you can pull down to hide wiring through and I just wired them to the rear boot speakers. I also have a couple of small box speakers mounted down in front of the rear seats I just wired everything to rear speakers. I pulled out the ugly rear speakers and bolted in a couple of home theatre floor stand jobs. It's pretty awesome if I may say so lol.
Check fusible link connector mine was doing the same thing and I found the connector was full of road grime. Don't ask me how road grime gets into a connection but it was in there. Spray it out with electrics cleaner and maybe tape it up to stop it happening again.
Switched my 3L engine oil to Synthetic?
Terranovation replied to maddmark1981's topic in General Forums
I have a TD27 and in Australia we have quite a warm climate so I use Semi synthetic 15w50. It's a thicker oil but it's needed especially in summer. -
Wouldn't start this morning, totally dead! 13 volts at the battery. Checked fusible link connector, was full of road grime. Cleaned it out and she starts right up! Thinking about cutting out the whole fusible link section and using some heavy gauge wire with an 80a fuse so if it happens again it's just a matter of replacing the fuse instead of fiddling with wires. -
Replaced my alternator today with the old one I got back from the electrician that had a refurbish. No more grinding noise and the charging isn't the best so now I'm suspecting it's the battery. If it's not one thing it's another. -
Amazing what a bit of love and care can do for these Pathys. Nice work man!
To do a proper trans fluid level check, drive for 20 minutes so trans is fully warmed up, check the fluid level with the vehicle on flat surface, gear in 'P' and engine is running. Check the fluid is within the HOT mark on the dipstick. You can use Dexron III ATF although in the service manual it says II but III is fine. Do not use DEXRON IV or anything else. I would start by giving the bottom of the trans pan a good decrease and wipe off with an old rag, go for a drive for 10 or so minutes then see where it's coming from. Maybe like you said the previous owner put the gasket on the wrong way or didn't use sealant? Maybe they overtighten it?
