nissandoms47
Everything posted by nissandoms47
It depends on what kind of fan you're going to get. What people usually do is go to autozone and buy a tempurature sensor relay and it has a little probe that you stick into the fins on the rad and when it reaches a certain temp it turns the fans on. I would just wire it so that it always turns to the high setting. Thats how mine are.
The thermostat is all mechanical. When it reaches a certain temp it opens.
So in normal terms she has to just go buy a new 02 sensor? lol
Multiple times. I was just worrying you haha.
Just buy the AC 2" lift. You thing with stiffer coils the ride would get worse but it actually improves the ride and handling.
Lol its a CV axle. Driveshafts are way different.
Lol, I would highly recommend armoring those control arms. The angle iron i welded onto mine has already payed off.
It shouldn't really matter lol.
yeah..
you mean the CV halfshaft? you'll probably have to take it apart again and see whats going on.
Didnt go past 2500 rpms? Sounds like a MAF problem.
And one has angle iron just welded on the bottom lol.
For that much work, just swap in a D44 or a ford 9". You'll have to shave that WD axle clean to make it work on the r50.
Guess ill post some up,
r50 ABS sensors are located on the ends of the axle tubes so by swapping 3rds you'd lose ABS unless you can figure out how to make the wd one work.
I second the rack bushing. Ive already gone through 2 of them. And if they're gone it'll prevent you from getting a proper alignment.
1998 Pathy Air Conditioner Hvac Control Panel
nissandoms47 replied to r0x's topic in 96-2004 R50 Pathfinders
He doesnt have the climate control (digital) if he has a cable behind it. -
Whats Up With The Small Cup Holders ? Any Remedies
nissandoms47 replied to trashman's topic in 96-2004 R50 Pathfinders
Or in between the legs.. lol. But yeah its hard sometimes to fit 2 fairly big drinks in the center console cup holders. -
$77 each for a new control arm with bushings and a ball joint? It would be cheaper just to buy 2 of those instead of buying 2 new balljoints, bushings and all that.
Noise From Rear End After Ac Lift Install?
nissandoms47 replied to nmpath's topic in 96-2004 R50 Pathfinders
Maybe your shocks arnt tight enough. -
I easily bent one of my "round holed" wheels. I guess Dan just doesn't wheel hard enough lol. I guess I was cursed because this happened on a trail called "Steel Bender".
On these trucks probably.. lol
Which Suspension lift package?
nissandoms47 replied to OR99.5Speed's topic in R50 FAQ's & Pinned Topics
I did, they rode great. The set of coils I had I bought from a buddy (entrophy98) and they were good to him too. They now sit on a 3rd pathfinder (turbopath) and still ride great. entrophy and I just needed a bigger lift. -
Thats cool, i need to get a new AC compressor and power steering pump. the bearings or whatever in both of them are shot to hell.
I'm down, im only 3 hours away from moab so its not biggie for me. Ive been there 4 times now, know the area pretty good. When would you think of doing it? July or August? It gets pretty hot right around this time so if you were going I would shoot for late July and whenever in August.
