Anybody for a run?!
How 'bout the hydro line via California Road. I'll throw in May 1st as a potential date. Thoughts and opinions...
P.S. Maybe we could even camp out!
I used a screw driver and a hammer. I hit the flange in different spots to shock it and then tapped it out with the screw driver to separate it from the hub.
HTH!
Welcome to the club!
Regarding your hard starts: I would also recommend changing your fuel filter. Before changing mine my truck took (in my opinion) too many turns to fire, after the new filter it fires right up. I think a full tune up would be a good idea aswell, your truck will run better and you'll have the peace of mind knowing when it was last done.
Best of luck!
The wood trim around the vents pops off first, then you remove two screws at the top of the centre console wood trim and pull the rest of it off.
I found out how here, http://www.nicoclub.com/FSM/pathfinder/, under idx.pdf.
HTH!
You should measure how much the axles stick out from the hubs (with the auto-hub and drive flange off) on both trucks. If both stick out the same amount I would imagine the auto-hubs would work fine.
