Gauge cluster cleanup
Tungsten
If you ever want to take your gauge cluster out and clean it, here are some tips (for the square flat dash model):
1. Only remove the plastic bezel around the gauge faces and nothing else. Don't only remove the clear plastic screen and spray cleaner on the bezel. This is how I lost my numbers on the tachometer.
Remove this assembly to clean, you can separate the two pieces if you want. Also, it is safe to use cleaner on these two pieces. Do not clean the rest and if you absolutely have to, do not use a cleaner, only water and a microfiber towel.
2. Use the black tabs to remove the bezel. Don't forget to remove the clock adjustment knob, which is held on by a screw.
OOPS! At least it was already somewhat broken anyway...
I've pulled apart several of the round style and it is the same assembly with the same damn little clips that seem almost impossible not to break. LOL at the numbers, if you had the round dash I'd send the part that is sitting in the garage...
The circled fasteners remove the following parts:
Do not touch other screws. You also have to remove all the other gauges before removing the speedometer and the odometer.
Edited by Tungsten
  • 4 weeks later...
