transmission temp sensor...
Guest kb1jki
Guest kb1jki
ah, I guess the transmissions most prone to failure are '98's; but alot seem familiar with the overheating issue. I am not the first to be replacing one! so, if one wishes to monitor the temp of the transmission -how should it be done? what kind of sensor where? and what temp is "bad"? :blink:
  • 13 years later...
I wish someone had answered your question - Cause I need to know too! I don't get over drive till it's really hot. When on the hiway it shifts between 3rd and over drive - ...a LOT with no hills in sight.
Mine has been acting weird over the last few years - it takes more and more and more time to shift into overdrive every winter. Now this. Lemme know if U get an answer.
Cheers
Yes - pls see my post TRANSMISSION WOES - thanx
Sorry - I just saw this now...this particular email went into my junk folder for some reason..just this one? WT?!!
