Body Lift on Pathfinder Vg30 AT
steeve
Hello everybody,
My name is Steeve, and I live in France.
I would know if is it possible to put a body Lift on a Pathfinder Vg30 AT 1992 ?
Is there a problem with the lever ?
And sorry for my language if is not very good ...
The auto trans shifter connects to the transmission through a cable. My understanding is that the cable has more than enough slack to accommodate the lift, so this isn't a problem. The transfer case shifter may hit the floor after the lift, in which case you will need to bend the shifter or notch the floor.
  • 3 weeks later...
The easiest solution for the transfer case shifter is to bend it forward slightly. The other option is to remove it, cut it and extend it by the same length of body lift installed. Last option, cutting the floor, not recommended but people have done it.
