neutral safety switch on manual
Greetings, all you pathy enthusiasts.
I am attempting to replace the neutral safety switch on my manual without dropping the transmission. It is very hard to get to, let alone get a (18 or 19mm?) wrench on it.
Does anyone have any tips on this process?  Most of the videos I found were dealing with automatic transmissions.
Thanks for any advice!
I haven't messed with one but I'd pull the shift boot and see if you can get it from above. Might have to pull the console and take the plate off the trans tunnel if the shifter hole isn't big enough.
  • 4 months later...
