DonutHands Posted March 22, 2022 Share Posted March 22, 2022 Rear muffler is gone, the rest is decently rusty, so want to just swap out the whole thing behind the cats. I often order parts from rockauto but I don't see a full exhaust package and ordering piece by piece would be much more than buying the whole thing elsewhere. Just wondering if anyone has a recommendation. Also found my exhaust leak under the hood. Cracked manifold. https://imgur.com/a/3HoU3uf Has anyone used JB Weld fiberglass wrap or high temp putty for something like this? Not as a permanent fix, but I need to get smogged ASAP. I have time for an exhaust replacement, but not digging under the hood to replace the manifold at the moment. Link to comment Share on other sites More sharing options...
AR97Pathfinder Posted March 22, 2022 Share Posted March 22, 2022 There should be options for the rear resonator and then the front pipes and center muffler as a single piece. https://www.rockauto.com/en/moreinfo.php?pk=268863&cc=1212051&pt=10038&jsn=704 https://www.rockauto.com/en/moreinfo.php?pk=2461638&cc=1212051&pt=5872&jsn=664 There are a few more options of varying prices than what I posted above . When I swapped my exhaust I purchased from Rockauto, but at that time they also had the Bosal brand available. Good quality, its been about 4 years so far and no issues or a spec of rust. And I live in NY. As for the manifold, I'm not too sure. Link to comment Share on other sites More sharing options...
DonutHands Posted March 23, 2022 Author Share Posted March 23, 2022 As far as I can tell, the links you posted up are for specific parts of the parts diagram on the same page. They do not include all parts shown in the image. Link to comment Share on other sites More sharing options...
AR97Pathfinder Posted March 23, 2022 Share Posted March 23, 2022 (edited) Yes one is the entire rear resonator and the other is for the center muffler up to the cat. That makes up the entire exhaust system after the cats which is what you mentioned you were looking for. The diagram does show individual parts but the link themselves carry the part for what you are looking for. Cycle through the pictures on the link. Edited March 23, 2022 by AR97Pathfinder Link to comment Share on other sites More sharing options...
