Torsion Bars
Looks good :Aok:
Did you re-index before cranking them?  ...if not and you maxed them out, or nearly did, you may consider re-indexing then adjust for height.
Looks good! I remember mine took a few rounds to get right. I went too far with the first adjustment and it settled out way higher than I wanted.
If your adjusters are hanging below the crossmember, you can reindex like Redpath said to tuck them back in. Otherwise they can catch on things.
