UPDATE - The host suffered a "Catastrophic Hardware Failure" (*specifics not shared) on 01/13 and the "latest available" backup for the website and database were restored.  At this point they have been unable to recover any later versions of the database.
     We are going to give them another 72hrs to pull off a miracle and find something later than 05/21 before we fully move forward with normal forum operations.  Maybe we'll luck out, but to be perfectly honest, it's not looking good.
     It is still recommended that new members wait to register for the time being, as any new accounts created before our final decision on a path forward is made, may not exist once this is taken care of. This is also true for new topics, posts, status updates, profile & account changes, etc.
As always, we appreciate your patience as ask that you hold on just a little longer.
-NPORA Mod Team
*Updated: 01/17/2022 6:54PM PST
Door "Ajar" light wont turn off
WD40
My 95 Pathfinder for the last several years has the "Door Open" or ajar symbol lit constantly  even though all fo the doors are closed.
I assume this is one of the sensors at the doors - one of which on my car the rubber part has worn away.
I've had to pull the fuses for the radio/interior lights or I get a dead battery as the lights stay on -- plug it back in when I drive out.
How does one figure out which sensor is bad without replacing all 4.... or 5 if you count the back.???
Appreciate any direction, helpful hints, etc.
WD40
Check whether the cargo area light is on. The cargo light only comes on if the rear door is open. (At least this is how my '93 was set up; I'm pretty sure '95 is the same.) If the cargo light is on, it's the switch in the rear door, which is a common problem that I had on my '95 too. I've read you can fix it by shimming the striker. Mine was beyond that (or I did it wrong) so I ended up disconnecting the wire and teeing it into the switch for the tire carrier warning light instead. This worked great once I figured out it needed a diode to stop the dome light from backfeeding the tire carrier light on the dash.
If the cargo light is not on, it's a door switch. To track down which it is, disconnect one at a time until the lights go out (obviously keep the other doors closed until their switches are disconnected). Start with the one that looks torn up.
If it's one of the side door switches, you may be able to get it working again just by popping it apart and clearing it out. Something to try before ordering a new one, or a temp fix until the replacement shows up.
