Hey guys its been ages since Ive been on this site and just want to say hi to everybody. Ventured into a different hobby and also bought a 2015 Nissan xTerra PRO 4X for my daily driver but I miss my pathy so this summer Ive decided to bring her back to life
I have 92 Pathy that was stolen and was recovered after a few weeks. Completely restored it from outside in. Changed all the oils plugs timing belt computer , you name it. Shes been modified already before it got stolen and if I wouldve moved the ECU behind the glove box it probably would have never stalled when we recovered it in maybe buried 3 feet in mud at the local orv park.
Its been 10 years or so after restoring and it fired right up and drove it around and runs strong with no issues, everything worked as it should then decided to just store her in the garage. About 6 years ago I started her again and fired right up but theres white smoke so I was hoping it was condensation, checked oil and no milkshake there.
If you guys can please tell me how to properly drain the old fuel without taking the gas tank out or letting it run through my injectors by letting it run out. I spoke to another member here and he told me how to drain the old fuel by disconnecting the fuel line going to the injectors unfortunately thats all I can remember.
Your help and expertise is greatly appreciated. Thanks in advance and yall stay safe
If you disconnect the fuel line at the fuel filter (in the engine bay), you could connect up a hose to a jerry can, jumper the fuel pump relay, and let it pump most of the fuel out that way. To get the last of it, you'll need to remove the fuel pump (under the cargo area carpet, guessing you know that given how much you've done with it already) and pull out the last of it with a siphon or a lawnmower-style electric fuel pump. Might be better to drain it all that way, actually, so you're not running not-gas-anymore through the fuel pump. I would take a look at the inside of the tank before deciding for sure that you're not going to drop it. I've seen some awful schmoo in tanks that have sat. Hopefully yours isn't too bad. Welcome back, and good luck!
Thats a beter idea. I have a syphon I use on my mowers. Thanks bud I sure appreciate it
On another note, If I do have some gunk built up on there or what should I be looking for and need to do to clean it?
Hopefully all you'll find is orange gas that smells like wood stain and a little sediment in the low spots. It doesn't need to be perfect, but the less loose stuff you've got waiting to clog the fuel pickup, the better.
The tank for my dad's F150 had a layer of white crap at the bottom, which I removed with a wire wheel for a drill, extended by welding a few feet of steel rod to it so I could work the end around inside the tank. This worked pretty well. If it's bad enough to warrant this, I would go ahead and drop the tank. I've heard of people cleaning rusty tanks by sticking a chain or something inside and just shaking the hell out of it so the chain bangs around and loosens up whatever's in there, so that's another trick to consider if it's right proper crusty inside. Obviously make sure the tank is empty and the vapors are gone before getting anywhere near it with anything that makes sparks.
The worst I've seen was a Jeep tank that sat full of gas for something like fifteen years. The substance formerly known as fuel had eaten through the sides of the tank and congealed into a thick black schmoo that moved like silly putty and looked like bear crap. There was no saving that tank.
Thanks again bud. I hope theres not too much gunk on there but worst comes to worst Ill do the chain trick or try the wire wheel brush fist. I think I tried something like the wire wheel brush attached to a dremel with a flex shaft on our old water heater to get the build up calcium in the bottom and sides lol. It worked too
