WyKi 4 #1 Posted Tuesday at 12:42 PM Hey Guys, so I installed new struts/springs/mounts and sway bar links on the R50 and now when I engage 4-HI it pulls to the left. In 2-HI it drives just fine. Any ideas of what could be the issue? Thanks Share this post Link to post Share on other sites
Slartibartfast 1,374 #2 Posted Tuesday at 08:12 PM That's an odd one. Sounds like something in the front end is loose and when the front wheels are pulling, one of them (probably right front if it's pulling left) is moving forward in the wheel well, screwing up the camber/caster/toe on that side and making it pull left. In 2x, it's loaded the other way by drag, and sits closer to where it should be. Normally I'd guess at bad LCA bushings, but if this started after you did struts etc, I'd check your work there first. Maybe the strut top is shifting around? Seems like you'd have a hell of a racket if something was just loose. Share this post Link to post Share on other sites
WyKi Topic Author 4 #3 Posted Thursday at 08:42 PM Everything was torqued down to spec and double checked on my work. I don't hear any rattle either. It's been cold out so I'll check to see if a lca is bent or something Share this post Link to post Share on other sites
