Hi, yesterday happened something very strange, I was driving and I stop in front of a traffic light and when it turned to green I accelerated normally not hard, not slow, and my pathy started to have intermitent acceleration and almost it turned off, I accelerated slow and started to work fine and then I stopped and it did the same thing, I turned it off and when I tried to turn it on didn't started at all.
I disconnected the battery, waited for 10 seconds and when I plugged it back I could start the pathy again but the problem persisted, and after a while a check engine light showed up. I wonder if someone had a similar issue?
I'm waiting Monday to arrive so the mechanic can plug the scanner and check the failure code
