BamaQX402
Cheap eBay manual locking hubs
So I bought a set, made a world of differance. But now every so often on the passenger side it's making a buzzing sound for an instant, and once yesterday I was pulling a trailer & when I had to stop suddenly it did it.
Did I waste my money on those? Am I ruining my axle? I have a set of new axles...
I've had some chatter on a hub before.  A little lubricant inside seemed to help.  Just don't gob it up with grease.
Yeah I didn't add any, it had a pretty good coating on them, I figure once they wear in some it will stop. I need to lock them and see if it persists, just to verify. I made a point to jack it up and try to wiggle tires to check bearings/ball joints, nice and tight.
Thanks
So when I lock these hubs the loud noise stops, however now I do hear a constant faint noise. I believe when I unlock them they allowed the bearings to overclock, thus letting me know it's time for new ones, I bought this off a lot that someone traded in, so I don't have any history. With almost 200K showing and the fact that all the bushings are bout shot, I'll add bearings and go ahead and do the steering while I'm rebuilding the suspension.
Should I go ahead and plan to do rear bearings? I'm not too enthused to pull rear axles...
Yeah, if you're hearing a noise when the hubs are locked, it can only be the bearings.
The rear bearings are a bit more work...you can't replace those without disassembling the entire axle shafts.  Might be time for maintenance, but if you can't sense a problem, I'd probably let them slide for now.  It's probably not something I'd do unless you had more things to do while everything was down, like driveshaft u-joints, seals, etc.
  • Thanks 1
