Darylkeleny Posted April 12, 2020 Share Posted April 12, 2020 Hey guys, I got a 02 se and just bought it so I don’t know much about it! First Nissan I’ve owned and trying to learn the vehicle hoping you guys might have some ideas! Most of the time she fires up right away, but sometimes I’ll turn the key and nothing so keep turning off and on and eventually she starts some times half hour sometimes 5 min. Any thoughts on where to start diagnoses? anyone have this problem? Link to comment Share on other sites More sharing options...
mjotrainbrain Posted April 16, 2020 Share Posted April 16, 2020 Moved from R50 FAQ section to regular R50 section, as this is a personal issue and not an FAQ, and also it will get better visibility in the regular R50 section. Link to comment Share on other sites More sharing options...
Darylkeleny Posted April 17, 2020 Author Share Posted April 17, 2020 Mjotrainbrain thanks I’m new at this Link to comment Share on other sites More sharing options...
CALPATHY Posted April 17, 2020 Share Posted April 17, 2020 If it is a manual, the clutch switch could be wearing out. Link to comment Share on other sites More sharing options...
Mr_Reverse Posted April 17, 2020 Share Posted April 17, 2020 Does the security light turn on when you are trying to start and it is acting up? Just one of the possibilities. More likely a worn ignition switch though. I have seen a lot of bad ignition switches in older Nissans. You might want to check and make sure the battery terminals are clean and tight. 1 Link to comment Share on other sites More sharing options...
Darylkeleny Posted April 17, 2020 Author Share Posted April 17, 2020 Just replaced the battery but I will check next time it happens for security light and Look at ignition switch thanks for the tips anything help Link to comment Share on other sites More sharing options...
