RustFlames Posted April 2, 2020 Share Posted April 2, 2020 Well I’m Just waiting on getting my Lsd back with new bearing and races, I managed to get everything apart except for removing the race from the pinion gear. Also waiting on getting back my rear axle from the bead blasters.I’ve had no luck from the dealerships or online finding a new set of backing plates. Hate to put all new hardware together just to slap it on some swiss cheese mounts. Pathfinders in the pick n pull yards are usually more rotted out than what I already have. Local stealership tells me it’s a discontinued item, keeping the dust out of my drum brakes is all I want, anyone ever have any luck finding a suitable replacement? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
SpecialWarr Posted April 4, 2020 Share Posted April 4, 2020 Just did a quick shop on eBay, that proved to be useless! Maybe try signing up to eBay australia, since Thailand has a huge aftermarket parts for the WD21, you might be able to track something down there. Link to comment Share on other sites More sharing options...
FirstGenFreak Posted April 5, 2020 Share Posted April 5, 2020 I can check eBay Aus for you, just let me know the items Link to comment Share on other sites More sharing options...
RustFlames Posted April 6, 2020 Author Share Posted April 6, 2020 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FirstGenFreak Posted April 6, 2020 Share Posted April 6, 2020 Will have a look for you. There is a guy on our local FB group selling a complete axle, he might be happy to remove the backing plates? can put you in touch? Link to comment Share on other sites More sharing options...
RustFlames Posted June 11, 2020 Author Share Posted June 11, 2020 finally got the axle coated, I marred up the flange when I was separating the diff, polished it up with some memory cloth still waiting to have the new bearings and races installed Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RustFlames Posted September 3, 2020 Author Share Posted September 3, 2020 was unable to replace my backing plates so I bead blasted them as best I could and threw on some gloss black powdercoat I also did the rear axle hubs, taping off carefully where the bearing and seals sit, just getting them pressed in and mounting them when I get the new seals and bearings. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
