Jhurkmans Posted December 18, 2019 Share Posted December 18, 2019 Sorry for posting so much but my pathy has abunch of issues but does anyone know the standard idle rpms for a 1992 xe v6 pathy? Link to comment Share on other sites More sharing options...
Strato_54 Posted December 18, 2019 Share Posted December 18, 2019 if i had to guess anywhere between 700 - 1200 Link to comment Share on other sites More sharing options...
joshrichard Posted December 18, 2019 Share Posted December 18, 2019 if i had to guess anywhere between 700 - 1200800 has been the sweet spot for the two that I’ve hadSent from my iPhone using Tapatalk 1 Link to comment Share on other sites More sharing options...
onespiritbrain Posted December 18, 2019 Share Posted December 18, 2019 My FSM says 750 Link to comment Share on other sites More sharing options...
Slartibartfast Posted December 19, 2019 Share Posted December 19, 2019 They'll idle higher when cold. Mine idles up 1500ish when it's cold, then drops once it warms up (FSM says 750 RPM +/- 50). The EF&EC section of the service manual does have a procedure for adjusting the idle speed, but it assumes that the truck is running properly to begin with--don't adjust the IACV to try and mask some other issue. What's yours doing? If you don't have the service manual, the '90 manual from cardiagn is probably as close as you'll find for your '92. Nico has a '94/'95 manual that is mostly the same, but I keep finding out about weird little things that changed around '93. 1 Link to comment Share on other sites More sharing options...
