Mrelcocko Posted November 28, 2019 Share Posted November 28, 2019 Hey guys does anyone know what size the trans drain plug is? I'm looking to install an oil temp gauge for the transmission and was gonna use the drain plug as my input location. Sent from my SM-S367VL using Tapatalk Link to comment Share on other sites More sharing options...
Guest Posted November 28, 2019 Share Posted November 28, 2019 Hey guys does anyone know what size the trans drain plug is? I'm looking to install an oil temp gauge for the transmission and was gonna use the drain plug as my input location. Sent from my SM-S367VL using Tapatalk M10-M12? Its the same as engine oil plug. Sent from my Pathfinder Link to comment Share on other sites More sharing options...
Mrelcocko Posted December 2, 2019 Author Share Posted December 2, 2019 Thank you sirSent from my SM-S367VL using Tapatalk Link to comment Share on other sites More sharing options...
Mr_Reverse Posted December 3, 2019 Share Posted December 3, 2019 Aren't you worried about damage to the sensor since it will be on the bottom of the pan and begging to snag something? I had briefly thought of doing the same thing, but decided it would be too exposed there. So it wound up in a T fitting on the transmission outlet line. 1 Link to comment Share on other sites More sharing options...
Mrelcocko Posted December 3, 2019 Author Share Posted December 3, 2019 Hopefully I can find a drain plug with the center cut out to help recess it just a tad. I very very rarely if ever go off road. More on the street side of things.Sent from my SM-S367VL using Tapatalk Link to comment Share on other sites More sharing options...
