Bumpinryno Posted September 15, 2019 Share Posted September 15, 2019 Does anyone know if a manual transmission swap I put together for my 02 supercharged frontier will work on my 95 pathfinder instead? I have all new parts ,including flywheel, clutch, slave,master,etc Link to comment Share on other sites More sharing options...
Slartibartfast Posted September 16, 2019 Share Posted September 16, 2019 Part numbers are different for the MC and I'd be surprised if a Fronty pedal box fit a Pathy firewall. The rest should fit right up. Make sure you've got the right bolts for the flywheel. Link to comment Share on other sites More sharing options...
Bumpinryno Posted September 16, 2019 Author Share Posted September 16, 2019 Thanks for the reply,believe it or not it looks like the pedal assembly should bolt right in also. But if not I can get the correct one or fab this one to work. Thanks again Link to comment Share on other sites More sharing options...
Slartibartfast Posted September 16, 2019 Share Posted September 16, 2019 Good luck and let us know how it goes. It'd be good to know if the Fronty pedal box turns out to bolt up. Link to comment Share on other sites More sharing options...
