JackStraw1
Door lock cylinder
Hey all,
Long time.
Looking for driver's side door lock cylinder for 94 Pathfinder SE with power door locks.
Has 2 flat spots on it where the C - shaped switch assembly slides on.  Can't find in the aftermarket parts world. I'll take the whole door if someone is parting out and close enough for me to pick up.
I'm in Northwest Pennsylvania
I may have the cylinder case, will look little later, If I have it I can also rekey the lock to match yours.
are you looking for the casing or the whole cylinder with key?
I am looking for the whole cylinder. But....I did not realize that the casing could be removed. I'll take another look at it today and see if mine can be taken apart
Here's what I've got. The pic on the bottom shows how it is supposed to look. on the top is the broken unit I've got. I guess if I pull the circlip on the end of the cylinder, the inner workings will slide out, so maybe I only need the cylinder.
Edited by JackStraw1
