Micfly
How to remove center console? *clip*?
Hello trying to remove center console but ran into a problem with trying to remove the back screws not sure if there is a certain way to get the box to unclip or another way to get to the screws been at this for about an hour with no luck
You’ll need a long philips head screwdriver to reach the bottom of the box. There might be a piece of rubber or something at the bottom blocking access to the holes. The box with the cup holders slides into the console but is screwed in so the screws hold it and the console down. Does that make sense?
Oh ok I get it looking at it now there is a peice of carpet at the bottom I need to lift up and the screws should be there if I'm understanding right thanks
