VegasR50 0 #26 Posted August 12, 2020 On 10/20/2019 at 9:48 PM, jlduthie said: Slow going but front all back together, minus missing link for now. Started the rear today - just shocks and coils for now but one issue: Even with the sleeves in the lower bushing of the Bilstein 5125 there's still play between the 1/2" ID of the sleeve and the 12 mm bolt, as you would expect. I haven't seen any mention of this issue on here (seems more commonly that the lower mounting bolts are 14mm and so too big for the sleeve). In the event that I can't easily source a 5/8" OD / 12 mm ID sleeve, is there any downside to increasing the bores in the shock mounting bracket to 1/2" and just using new grade 8 bolts? Looks like lots of material to allow for this slight increase in hole diameter. What did you end up doing for the Bilstein 5125 lower bushing bolt and sleeve? I plan on installing the same shocks soon with the LR 9447 springs Share this post Link to post Share on other sites
jlduthie Topic Author 33 #27 Posted August 12, 2020 10 hours ago, VegasR50 said: What did you end up doing for the Bilstein 5125 lower bushing bolt and sleeve? I plan on installing the same shocks soon with the LR 9447 springs Drilled the mounts out to 1/2”. It’s a .028” increase in diameter so lots of material left. Then just used the supplied 5/8 OD 1/2 ID sleeves with grade 8 bolts. Share this post Link to post Share on other sites
VegasR50 0 #28 Posted August 15, 2020 On 8/12/2020 at 9:18 AM, jlduthie said: Drilled the mounts out to 1/2”. It’s a .028” increase in diameter so lots of material left. Then just used the supplied 5/8 OD 1/2 ID sleeves with grade 8 bolts. Thanks, will be doing this soon Share this post Link to post Share on other sites
taberwit 1 #29 Posted October 27, 2020 On 7/28/2020 at 7:09 AM, jlduthie said: Hahaha Canadian speed holes. Haven’t heard that before but definitely using it. That’s the first carrier I’ve seen at yard in forever. They seem hard to come by too from this forum. I just picked up a carrier from the scrap yard today. I lucked out because the R50 I got it from wasn’t on the yard manifest yet. This may be a dumb question, but is there a way to mount this to a wd21 or an R50 that doesn’t have the mounting holes already? Share this post Link to post Share on other sites
Slartibartfast 1,352 #30 Posted October 27, 2020 Yes. Trucks that came with the carrier have reinforcing plates, but members here have found other ways. The R50 rack is kinda rare, so, good score! The R50 and WD21 carriers are different. Share this post Link to post Share on other sites
jlduthie Topic Author 33 #31 Posted November 23, 2020 Been a while! The thread linked to the previous post is a fantastic resource. Just a couple small updates: 1) Earlier this year the exhaust rusted off aft of the muffler so replaced muffler and everything back. More aggressive than stock - sounds fantastic at 2500+ rpm with the pedal down - but as quiet as stock when cruising. 2) Hella 450 fogs to replace stock. Removed a section from bumper to accommodate larger fogs, filled the voids, and prepped and painted entire bumper flat black. 3) Indicator for hubs locked/unlocked. Just an illuminating switch wired to ACC wire for head unit. 4) Full exterior LEDs minus front indicators, headlights, and fogs. Load resistors for rear indicators to avoid hyper flash; attached to inside of rear light housing with heat-conductive double sided tape. 5) SFD kit from Pines to Spines is sitting in a shipping warehouse in Montana waiting for the border to open... No access to garage at the moment so likely that’s it for the winter, though I may try my hand at upholstery and repair the driver’s seat. Everything I’ve found in a yard has been pretty nasty looking. Major plans for next year or two include the rear tire carrier mod, new fenders at all 4 corners, new rockers, SFD kit with 33s, and possibly gear ratio change plus/minus Lokka for the front diff. I’ve toyed with the idea of a SAS for the front and a heavier rear axle along with a Cummins 4BT but that fab is on hold for a long while and I think that motor is just too heavy. 2 Share this post Link to post Share on other sites
98dreamer 0 #32 Posted November 29, 2020 On 10/26/2019 at 11:08 AM, jlduthie said: Thanks Ole_Rosie_R50! After 21 Alberta winters I'm just glad it all seems like body rust and the structural bits seem relatively OK. All done for this year - unheated detached garage and Edmonton winter setting in haha. Body work next year, also steering rack and rear upper and lower trailing arms. Front: OME MD springs, KYB GR-2 struts, SFCreation 1" spacer, new lower control arms, ball joints, inner and outer tie rod ends, sway bar links and bushings, missing link (1/4" x 1 1/2" steel bar stock) Rear: LR 9447 coils, Bilstein 5125 (33-185552) Wheels: ProComp Rock Crawlers with weights painted black Before: After: Here's what worries me the most — this rust above the windshield. Most other rusted panels I can find either at a JY (though mostly rusted through here) or can order bare panels, but the roof seems a) hard to find and b) I assume is difficult to replace anyways. Haven't done any bodywork before so can learn about that over the winter and try it next summer. Any thoughts greatly appreciated! Those Pro Comp Crawlers, are those the stock size? Or has anyone seen/heard of any 17" wheels being used? Share this post Link to post Share on other sites
jlduthie Topic Author 33 #33 Posted November 29, 2020 18 hours ago, 98dreamer said: Those Pro Comp Crawlers, are those the stock size? Or has anyone seen/heard of any 17" wheels being used? Yeah they're 15". 8" wide, -19 mm offset. 1 Share this post Link to post Share on other sites
98dreamer 0 #34 Posted December 18, 2020 On 11/23/2020 at 10:51 AM, jlduthie said: Been a while! The thread linked to the previous post is a fantastic resource. Just a couple small updates: 1) Earlier this year the exhaust rusted off aft of the muffler so replaced muffler and everything back. More aggressive than stock - sounds fantastic at 2500+ rpm with the pedal down - but as quiet as stock when cruising. 2) Hella 450 fogs to replace stock. Removed a section from bumper to accommodate larger fogs, filled the voids, and prepped and painted entire bumper flat black. 3) Indicator for hubs locked/unlocked. Just an illuminating switch wired to ACC wire for head unit. 4) Full exterior LEDs minus front indicators, headlights, and fogs. Load resistors for rear indicators to avoid hyper flash; attached to inside of rear light housing with heat-conductive double sided tape. 5) SFD kit from Pines to Spines is sitting in a shipping warehouse in Montana waiting for the border to open... No access to garage at the moment so likely that’s it for the winter, though I may try my hand at upholstery and repair the driver’s seat. Everything I’ve found in a yard has been pretty nasty looking. Major plans for next year or two include the rear tire carrier mod, new fenders at all 4 corners, new rockers, SFD kit with 33s, and possibly gear ratio change plus/minus Lokka for the front diff. I’ve toyed with the idea of a SAS for the front and a heavier rear axle along with a Cummins 4BT but that fab is on hold for a long while and I think that motor is just too heavy. I'm on the exhaust now. Having finally got the 3.3 purring. You said, you went with an exhaust more aggressive than stock... can I ask for more detail on this? Brands, process and all please. Share this post Link to post Share on other sites
jlduthie Topic Author 33 #35 Posted December 27, 2020 On 12/18/2020 at 4:24 PM, 98dreamer said: I'm on the exhaust now. Having finally got the 3.3 purring. You said, you went with an exhaust more aggressive than stock... can I ask for more detail on this? Brands, process and all please. Glad you got it working!!! Just brought it to a local exhaust shop. Told them I wanted something a little more aggressive than stock that would still be reasonable at 110 kph on the highway. Brand is Flo-Pro. I’m not sure of the exact model (other than that it’s from the Max series) but this is the website: https://www.flopro.com/max.html 1 Share this post Link to post Share on other sites
98dreamer 0 #36 Posted January 6 On 11/29/2019 at 6:46 PM, jlduthie said: Little update. LEDs bought for interior and brake lights but not in yet. New head unit installed. Bought from Crutchfield with kit and pretty much plug and play. Kit to concert from double to single DIN pushed the climate control panel up a bit but can live with that. https://imgur.com/gallery/PKVgM2d Have an oxyacetylene welding course coming up in January, then lots of body work and hopefully paint next summer! Holy smokes! Where did you get that fantastic carbon fiber trim piece, and did it come with the door trim as well? And your info and updates are great. Thanks a ton. Next issue for me is a slight hummm under acceleration at about 3k rpm in 2nd gear... Share this post Link to post Share on other sites
jlduthie Topic Author 33 #37 Posted January 9 On 1/5/2021 at 8:03 PM, 98dreamer said: Holy smokes! Where did you get that fantastic carbon fiber trim piece, and did it come with the door trim as well? And your info and updates are great. Thanks a ton. Next issue for me is a slight hummm under acceleration at about 3k rpm in 2nd gear... Faux carbon fiber came stock on this model for that year; I haven't replaced any interior trim. Good luck with that hum! Hopefully it's nothing major. Share this post Link to post Share on other sites
