A.Sans Posted May 1, 2019 Share Posted May 1, 2019 Hello, my front right auxiliary lights are out and considering headlight change or bulb replacement. Do you guys recommend any good aftermarket headlights or fog-lights? Thank you! Link to comment Share on other sites More sharing options...
Guest Posted May 3, 2019 Share Posted May 3, 2019 Stick with OEM. Anything aftermarket sucks and is inefficient. Link to comment Share on other sites More sharing options...
micahfelker Posted May 3, 2019 Share Posted May 3, 2019 I would just put LED's in your factory housings. They're bright as heck. https://www.amazon.com/HIKARI-Headlight-Conversion-Kit-9004-Adjustable/dp/B07GKKJ9M4/ref=sr_1_4?keywords=hikari%2Bled%2B9004&qid=1556850129&s=gateway&sr=8-4&th=1 I use this brand in both of my cars. If you order them you will not be disappointed Link to comment Share on other sites More sharing options...
PathyDude17 Posted May 3, 2019 Share Posted May 3, 2019 2 hours ago, micahfelker said: I would just put LED's in your factory housings. They're bright as heck. https://www.amazon.com/HIKARI-Headlight-Conversion-Kit-9004-Adjustable/dp/B07GKKJ9M4/ref=sr_1_4?keywords=hikari%2Bled%2B9004&qid=1556850129&s=gateway&sr=8-4&th=1 I use this brand in both of my cars. If you order them you will not be disappointed Ya, just make sure they aim up ok and have a good cutoff Link to comment Share on other sites More sharing options...
colinnwn Posted May 4, 2019 Share Posted May 4, 2019 I found warm white HID lamps on Amazon. I really like them. They can power out of my fogged lenses better than halogen. They are almost as bright as high beam on low, but so far the only times I've been flashed were towing a trailer. The high beams aren't good. They just have a halogen hi beam to get by inspection.If I could find some warmer LED headlamps I'd be tempted to try them. Sent from my SM-N950U using Tapatalk Link to comment Share on other sites More sharing options...
Sjackson2 Posted May 5, 2019 Share Posted May 5, 2019 Diode dynamics sl1 or morimoto 2stroke are the only led bulbs that belong in reflector housings Link to comment Share on other sites More sharing options...
ferrariowner123 Posted May 6, 2019 Share Posted May 6, 2019 JDM projectors are on the high end of the options but are an OEM Nissan part, so they fit perfectly and are OEM quality. Can be a little tricky to get a hold of but are so nice once you have them. -Kyle Link to comment Share on other sites More sharing options...
Mr_Reverse Posted May 9, 2019 Share Posted May 9, 2019 I put some Hikari LED conversion bulbs in my Sorento and have been very happy with them. They aimed and installed well. My 93 Pathfinder has some Sealight 9004 HB1 LED bulbs in it and they are working great. The lights have never worked so well and I haven't had anybody flash me with them. Now the yellow aftermarket LED fog lights from Nilight are painful to look at even at midday, so I don't run them much as a courtesy to on coming traffic. 1 Link to comment Share on other sites More sharing options...
KiwiTerrano Posted May 9, 2019 Share Posted May 9, 2019 (edited) JDM HID lights are fantastic. The low beam HID are extremely good, especially when paired with good aftermarket bulbs. I'm running Osram Nightbreaker D2S in mine and the light output is unbelievable. Better than any other vehicle I've ever been in. The high beams on the JDM lights are also great, they're shaped like driving lamps and output a good amount of light even with factory bulbs. Am contemplating getting a set of nightbreakers for them too in halogen form. My light output is on a par with all my mates with massive light bars haha Edited May 9, 2019 by KiwiTerrano Link to comment Share on other sites More sharing options...
