RegionRat85 Posted March 24, 2019 Share Posted March 24, 2019 Hello everyone, I'm new here. I have an 2006 Pathfinder LE. Just wanting to see what info is out there and maybe even see if I can help. 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted March 24, 2019 Share Posted March 24, 2019 If you're looking to build yours up, Fleurys makes a lift kit for the R51.If you haven't bypassed the trans cooler in your radiator yet, look into that. The factory rads weren't well made and the cooler tends to leak, mixing coolant and trans fluid into a pink mess known as SMOD (strawberry milkshake of death). Sounds like you can just swap a couple of hose connections and run the external cooler only. 1 Link to comment Share on other sites More sharing options...
RegionRat85 Posted March 25, 2019 Author Share Posted March 25, 2019 Hey, thanks for the pointers and the welcome! I know it had been taken in for the recall that I thought was for that before I owned it. Doesn't look like the original radiator. I'm thinking about possibly doing something with it. Not sure yet. I'm in the process of pulling some of the top end apart to fix oil leaks. 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted March 25, 2019 Share Posted March 25, 2019 (edited) Good luck with the leaks! I don't know if Nissan ever recalled the trans cooler issue. Might've been chain guides it was in for? The faulty rads were made by Calsonic, might help determine whether the one you've got is OE or not. Edit: more info and part #s in this thead. Edited March 25, 2019 by Slartibartfast 1 Link to comment Share on other sites More sharing options...
RegionRat85 Posted March 25, 2019 Author Share Posted March 25, 2019 Hey, thanks for the pointers and the welcome! I know it had been taken in for the recall that I thought was for that before I owned it. Doesn't look like the original radiator. I'm thinking about possibly doing something with it. Not sure yet. I'm in the process of pulling some of the top end apart to fix oil leaks. Link to comment Share on other sites More sharing options...
RegionRat85 Posted March 25, 2019 Author Share Posted March 25, 2019 (edited) I'm not sure why it sent that again. Haha I'm not sure if they did change out the radiator. I will have to check. The secondary chain guides was for sure a recall Yeah, she leaks alot it seems. Doing the valve covers for now then possibly the front cover, it's leaking as well. That's a big job though. One step at a time. Thanks for the info on the part #'s Edited March 25, 2019 by RegionRat85 Needed to add more. Link to comment Share on other sites More sharing options...
