Sjackson2 Posted March 13, 2019 Share Posted March 13, 2019 9 hours ago, MLML said: LR Direct is in England? Ships free and fast to US? Scroll down a couple threads and there’s a free pair of 9447 up for grabs. Just gotta pay shipping Link to comment Share on other sites More sharing options...
MLML Posted March 13, 2019 Author Share Posted March 13, 2019 No drive line issues at all. You may want to consider longer shocks but that’s true with stock springs and spacers as well. You likely won’t notice it on street driving, but if you take it off road you the shock will top out and limit your downward travel. Now that I think of it, you said the sound got better but is still there after installing new springs and spacers? Is it possible you’re hearing the shock bottom out over bumps? When I had spacers with stock shocks, sometimes when going over small bumps or small curbs I could hear/feel the shock bottoming out with a small clunk. I’m running f250 shocks now. It might be the shocks bottoming. It’s a pretty harsh bottom out sound. I replaced the shocks with standard length shocks. Maybe I should go longer? What shocks do you recommend? Do you still have those 9448s? They might work ok for me? If so, I’d gladly pay for shipping! I’m thinking that given I carry bikes on the back maybe the heavy duty 9448/9449s might be better? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Bax03SE Posted March 13, 2019 Share Posted March 13, 2019 I do still have the 9448 set. With the bike rack and stuff I think you would like the extra load capacity. The set I have had one coil cut so they give 3 inches of lift with no weight in the back. I used them towing a trailer with about 200 lb tongue weight and it would drop about an inch with the trailer hooked up. If you want to check shipping let me know, they’d be shipping from zip code 19720 and the box weighs about 15 lbs if that helps calculate. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
MLML Posted March 13, 2019 Author Share Posted March 13, 2019 I do still have the 9448 set. With the bike rack and stuff I think you would like the extra load capacity. The set I have had one coil cut so they give 3 inches of lift with no weight in the back. I used them towing a trailer with about 200 lb tongue weight and it would drop about an inch with the trailer hooked up. If you want to check shipping let me know, they’d be shipping from zip code 19720 and the box weighs about 15 lbs if that helps calculate. Sent from my iPhone using TapatalkSold! I will PM you details in a bit. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
MLML Posted March 13, 2019 Author Share Posted March 13, 2019 52 minutes ago, Bax03SE said: I do still have the 9448 set. With the bike rack and stuff I think you would like the extra load capacity. The set I have had one coil cut so they give 3 inches of lift with no weight in the back. I used them towing a trailer with about 200 lb tongue weight and it would drop about an inch with the trailer hooked up. If you want to check shipping let me know, they’d be shipping from zip code 19720 and the box weighs about 15 lbs if that helps calculate. Sent from my iPhone using Tapatalk PM sent, twice. Sorry trying to figure out how to use Tapatalk! Link to comment Share on other sites More sharing options...
MLML Posted March 13, 2019 Author Share Posted March 13, 2019 4 hours ago, Bax03SE said: I do still have the 9448 set. With the bike rack and stuff I think you would like the extra load capacity. The set I have had one coil cut so they give 3 inches of lift with no weight in the back. I used them towing a trailer with about 200 lb tongue weight and it would drop about an inch with the trailer hooked up. If you want to check shipping let me know, they’d be shipping from zip code 19720 and the box weighs about 15 lbs if that helps calculate. Sent from my iPhone using Tapatalk What shocks would you recommend with those 9448s? Link to comment Share on other sites More sharing options...
PathyDude17 Posted March 13, 2019 Share Posted March 13, 2019 4x4parts.com has shock options for 2” lifts-Rancho and Bilstein. Rugged rocks should carry the OME options Link to comment Share on other sites More sharing options...
MLML Posted March 13, 2019 Author Share Posted March 13, 2019 Just ordered the Bilstein 5100's with 2" lift. With the new 9448 springs my son should be stylin'! Link to comment Share on other sites More sharing options...
