VG34e Powered R50 Adventure/Build Thread
deltaR50
july 2015
hollister hills svra
11703283_854323514617326_789583997952793
10515150_854323554617322_879726210311208
more flexing!
10986498_854323577950653_143717768501582
11539034_854323594617318_255087323176136
11114082_854323607950650_890562911366587
1493483_854323624617315_5484240920470805
11696452_854323717950639_146232618402154
flexing with my crew
11728733_854323677950643_451941441705282
11010518_854323664617311_200783564355815
Edited by deltaR50
oct 2015
rola roof basket extension is added. remove the old factory roof rack broke on me so it has to go. also bought conduit clamps to mount the roof basket for more strength on the mount.
parts you need for low mount roof basket
only works if your roof basket has side pipes like rola vortex
parts needed
- m6 fender washer
- m6 stainless steel split washer
- oem roof bar mounts
- 1/4 inch m6x1.0 bolt
12115518_888838441165833_223736777599701
53559998_2029788733737459_30047807883916
53701937_2029788743737458_36899050980470
53410230_2029788837070782_63113597803927
54434708_2029788823737450_17074397500313
Thanks for sharing man.  How did you secure the jerry can to the tire carrier?  I've been wanting to do the same thing.
@TowndawgR50 did the same & then repeated it 3 times this last month for us. It works well. Smittybilt Jerry Can Holder. Consider putting in a CB tab while you’re at it. I’m contemplating a vertical Hi-Lift carrier as well.
im also on the same route. gonna move my hi lift on to my spare tire carrier when i get the chance. just been busy and working spot is starting to be an issue.
I bought this from Amazon for ~$60. It’s made for JKs but spans the facelifted tire carrier nicely just inboard of where the bars thicken. It will need to be welded on (Thanks[mention=37543]TowndawgR50[/mention]). There are multiple versions out there but this one is about the cheapest and the build quality & powdercoating are good quality & appear identical. I might have mine on in a week or two. It’s about 8# plus the weight of the Hi-Lift. I have my concerns regarding the weight but figure I’ll only have it there for rare technical trips. I can’t store mine on the rig long term since it sits in the ever present rain here & getting it up & down off the rack has always scared me a little (I so see that cradle popping the cargo area glass panel). This site is super easy to put on, take off, secure & is essentially out of my vision as well.https://smile.amazon.com/gp/aw/d/B07DCN7FYG?psc=1&ref=ppx_pop_mob_b_pd_title
  • mjotrainbrain changed the title to VG34e Powered R50 Adventure/Build Thread
I bought this from Amazon for ~$60. It’s made for JKs but spans the facelifted tire carrier nicely just inboard of where the bars thicken. It will need to be welded on (Thanks[mention=37543]TowndawgR50[/mention]). There are multiple versions out there but this one is about the cheapest and the build quality & powdercoating are good quality & appear identical. I might have mine on in a week or two. It’s about 8# plus the weight of the Hi-Lift. I have my concerns regarding the weight but figure I’ll only have it there for rare technical trips. I can’t store mine on the rig long term since it sits in the ever present rain here & getting it up & down off the rack has always scared me a little (I so see that cradle popping the cargo area glass panel). This site is super easy to put on, take off, secure & is essentially out of my cision as well.https://smile.amazon.com/gp/aw/d/B07DCN7FYG?psc=1&ref=ppx_pop_mob_b_pd_title
Yea i got my eyes on that too. Torn between where i just make a simple custom mount on the spare tire carrier. Ive had my hi lift jack mounted on my roof basket for at least 3 yrs now and it never got loose even once. Lucky.
Yeah, when I was in the desert it just stayed on the roof-not a good option in the PNW. Another option I considered was mounting it horizontally across the top bar of the carrier but it’s a little tight on our trucks and this leverages the weight out farther when open. Also, the position of the foot is a little problematic (probably outboard of the body) plus it seems more likely to “jiggle”. I chatted with an experienced JK owner I know and he said he’s had no problems with this vertical set up, including squeaks & rattles.
feb 2016
carnegie SVRA in tracy, california. weekend with my small circle
parts added
roof spot lights 7 inches HID 6k
front brush guard lights 7 inches HID 6k
48inches hi lift jack custom mounts on roof basket
12803220_952043051512038_571321215012833
12795323_952043344845342_185254919129199
12801098_954103811305962_538281617073152
3535_954103784639298_3967324259448941935
12802771_954103767972633_158413578505894
12800374_954103761305967_220947185729151
12814205_954103731305970_241676395425431
12805981_954103934639283_833243951033120
Edited by deltaR50
march 2016 update
snorkel installation
i had to be creative at least with this one. i almost went for the xj cherokee snorkel but i went for d22 navara snorkel as it has easier to custom pipe it to the intake. i eliminate the stock airbox and replaced it with spectre 5 inches inline intake  i had to make some adjustments to make the spectre to fit between the maf and snorkel.
1x silicone coupler reducer plastic intake tube 2.5 outside diameter to 3 inches outside diameter to maf
1x silicone coupler reducer from maf with maf adapter with 3 inches outside diameter to 4 inches outside diameter to inline intake
1x silicone coupler reducer from inline intake 4 inches outside diameter to snorkel with 3 inches outside diameter to mate.
53781174_2037705872945745_91088958769227
marking the spot where to punch a hole. eye balled it...................
53354567_2031015120281487_41534519246428
53674818_2031015136948152_52050782275963
tried to use the template for d22 just for the holes to bolt in.
53224155_2031015033614829_47340493446326
removed fender. as the spot where im trying to cut. i had cut it squarish only for me to make the intake tube fit. spray painted at least to prevent rust
53869301_2031015196948146_86744672793264
54436120_2031015066948159_72210100896315
53764571_2031015043614828_37068713870973
snorkel installed. truck still shiny lol
13124581_992695474113462_111323360813813
Edited by deltaR50
may 2016
sf bay area NPORA r50 meet Union City, ca
npora members xplor4 and enjoi408.i forgot mikey's npora user name. (gray r50 pathfinder)
13226791_995750577141285_689515402425659
13227007_995750573807952_179325036605563
13239172_995750597141283_433581781528231
13226846_995750603807949_304976447948837
13165866_995750643807945_507731358313062
13244840_995750657141277_839048521306624
13244666_995750697141273_376843298146765
13240581_995750720474604_298066305809252
13227110_995750753807934_925786655485596
  • Like 4
