deltaR50 Posted March 7, 2019 Share Posted March 7, 2019 hello guys. i just wanted to say Hi again. ive been a member here for a while now. go here and there once in a while. ive been building this truck for 4 yrs now and i just never had the time to create a separate build for this truck. will post pics and vid. stay tune! truck specs. 96 Se3.4 vg34e euro camsKr fab Sfd+aluminum 1 inch spacer front 5” rear 6” rear wj coilsKyb front struts5100 bilstein shocks rearCustom front bumper Smittybilt 9500 winchJeep fogsWelded frontNavara snorkel d21Spectre 4 inches inline intake33x12.50x15 cooper discoverer sttWarn manual hubs6k led headlamp bulbsAdditional aux fuse box Arb air on board compressor15x10 steeliesGas canCb radio2x 7 inches Rear led lights4x 7 inches front spotlights2x 7 inches front bumper lightsRock slidersGround kitTrasharoo lolfull catback exhaust new piped 2.5 with Flowmaster 40 Tow hitchNissan oem diff plateRola vortex roof rack with custom mounts for flush and low profile 3 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 7, 2019 Author Share Posted March 7, 2019 (edited) just checking local craigslist. no intentions of buying another pathfinder since i already have one. found this as a mechanic special. it doenst start. listed at $600. checked it out the bought it. towed it home. just turns out bad starter. 178k may 8 2014 Edited March 7, 2019 by deltaR50 1 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 7, 2019 Author Share Posted March 7, 2019 ******june-july 2014****** since i planned to build this one i decided to do a major tune up. so when i start building it for other uprgades i dont have to worry about its reliability. parts replaced were timing belt waterpump oe thermostatcamshaft seals oil pump seals sparkplugs sparkplug wires valve cover gasket valve cover screw and gromets intake manifold gasket intake manifold allen bolts (oe were rusted and falling apartt) heater hoses knock sensor painted rust protection for the heater pipes under the intake manifold cleaned egr new egr gasket new power steering. alternator and ac belts new radiator hoses new starter since im putting a new knock sensor. i pulled the intake plenum and manifold. heater hoses and knock sensor are pretty accesible while the intake mani is out. installed new gaskets and valve cover ones did the timing belt and waterpump gave me access to this might as well change it while im at it more work new valve cover bolts old place. where i learned how to wrench 1 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 7, 2019 Author Share Posted March 7, 2019 first drive after the full maintenance done. USS hornet august 2014 2 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 7, 2019 Author Share Posted March 7, 2019 other pics 2 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 7, 2019 Author Share Posted March 7, 2019 (edited) first off road trip after the full maintenance carnegie svra in livermore,california dec 6, 2014 Edited March 7, 2019 by deltaR50 4 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 7, 2019 Author Share Posted March 7, 2019 3 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 7, 2019 Author Share Posted March 7, 2019 (edited) may 2015 few months ago i got lucky that i found someone local that sell his sfd kr fab kit. i think its one of the last production run at the time. i think i paid $600 for everything at the time. 5100 bilstein shock wj coil spring 1 inche rear wj coil spring adapter steering extension strut spacers kr fab pan hard drop bucket sway bar links Edited March 7, 2019 by deltaR50 2 Link to comment Share on other sites More sharing options...
Sjackson2 Posted March 8, 2019 Share Posted March 8, 2019 Super jealous!! Link to comment Share on other sites More sharing options...
Jack9909 Posted March 8, 2019 Share Posted March 8, 2019 Wow awesome work! Great score on that sfd kit Link to comment Share on other sites More sharing options...
Mattmill91 Posted March 8, 2019 Share Posted March 8, 2019 That out at carnagie OHV? Looks like it. Your sorta local to me!!! I am in Stockton Link to comment Share on other sites More sharing options...
deltaR50 Posted March 8, 2019 Author Share Posted March 8, 2019 2 hours ago, Mattmill91 said: That out at carnagie OHV? Looks like it. Your sorta local to me!!! I am in Stockton yea. its in carnegie. years back. ive been also to modesto area. stay tuned. ive got @!*%load of pictures to post. 1 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 8, 2019 Author Share Posted March 8, 2019 2 hours ago, Jack9909 said: Wow awesome work! Great score on that sfd kit i know thanks! Link to comment Share on other sites More sharing options...
deltaR50 Posted March 8, 2019 Author Share Posted March 8, 2019 (edited) SFD install may 2015 before install rears front Edited March 8, 2019 by deltaR50 1 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 8, 2019 Author Share Posted March 8, 2019 (edited) may 2015 front struts removed 14mm x 3 on the tower. then 2x 21mm nuts for the spindle side placed jack stands on the transmission to hold the engine not falling off when the subframe is being unbolted. dropped the diff.bolted with 8x 17mm on the diff mount while the cv is bolted on the diff with 6x 12mm each side. its must easier to move the subframe without the differential bolted in. also gives you room to remove the engine mount nuts 14mm nuts steering link removed. Edited March 8, 2019 by deltaR50 2 Link to comment Share on other sites More sharing options...
mjotrainbrain Posted March 8, 2019 Share Posted March 8, 2019 Can't wait to see this build thread progress! I've seen what your rig looks like now on Facebook, so I look forward to seeing the story of how it got where it is. 2 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 8, 2019 Author Share Posted March 8, 2019 (edited) may 2015 front lift installation engine support block is in. subframe dropped ready strut spacer and nx 1 inch spacer installed Edited March 8, 2019 by deltaR50 3 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 8, 2019 Author Share Posted March 8, 2019 (edited) may 2015 rear removal of shocks and rear coils drill out the hole to fit the bolt for the 1 inch wj coil spring adapter. new vs old coil spring and rear shocks 5100 bilstein coil spring, rear shocks, extended sway bar links, kr fab pan hard drop bucket and 1 inch wj coil spring adapter installed Edited March 9, 2019 by deltaR50 1 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 9, 2019 Author Share Posted March 9, 2019 (edited) may 2015 after install sfd install front rear before after 2 inches coil spacer lift vs sfd 6 inches lift. both are my rigs. 245/75/16 vs 235/65/15 Edited March 9, 2019 by deltaR50 1 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 9, 2019 Author Share Posted March 9, 2019 (edited) may 2015 snatch me some 15x10 steel wheels off craigslist. also some meats 33x12.50x15 to go with the wheels so i can get rid of the ugly gaps. looks like rig is skipping leg day from the gym lol Edited March 9, 2019 by deltaR50 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 9, 2019 Author Share Posted March 9, 2019 (edited) first drive after fully installed the sfd and bigger tires/wider wheels. some flexing yea Edited March 9, 2019 by deltaR50 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 9, 2019 Author Share Posted March 9, 2019 (edited) may 2015 USS Hornet Edited March 9, 2019 by deltaR50 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 9, 2019 Author Share Posted March 9, 2019 (edited) june 2015 purchased used warn manual hubs here from another member. just dont remember who. it was steal. $100 for 2 pair of manual hubs. 1 pair is this warn and the other one was an oem manual locking hubs from nissan factory. warn manual hub installation. removed auto hubs, 6x nuts and studs, c clip installed warn hub Edited March 9, 2019 by deltaR50 Link to comment Share on other sites More sharing options...
deltaR50 Posted March 9, 2019 Author Share Posted March 9, 2019 (edited) july 2015 hollister hills svra testing the goodies gas can added on the factory spare tire carrier inspired by theexbrit also a member here. crazy flex! Edited March 9, 2019 by deltaR50 1 Link to comment Share on other sites More sharing options...
Sjackson2 Posted March 9, 2019 Share Posted March 9, 2019 Man your rig looks really nice! 1 Link to comment Share on other sites More sharing options...
