Sjackson2 Posted February 16, 2019 Share Posted February 16, 2019 So I know you can use a 2001 maxima maf on our pathys, but how does that work with them being a 5 pin versus the pathy 4 pin connector? The factory connector still snaps on just fine? 1 Link to comment Share on other sites More sharing options...
QuasarDecimari Posted February 16, 2019 Share Posted February 16, 2019 Just did this myself about a month ago. The 5th pin on the maxima is for a little thermistor that the pathfinder doesn’t utilize, because the pathfinder has an auxiliary intake air temperature sensor.It snapped on easily, fit perfectly in the stock housing, and boy did it restore a good bit of power. No issues to date! 1 Link to comment Share on other sites More sharing options...
Sjackson2 Posted February 16, 2019 Author Share Posted February 16, 2019 Is that what that little resister is on the side of the actual mag sensor on the maxima? Link to comment Share on other sites More sharing options...
QuasarDecimari Posted February 16, 2019 Share Posted February 16, 2019 Is that what that little resister is on the side of the actual mag sensor on the maxima? Yep. As far as I can tell, it looked like a little thermistor. The pathfinder doesn’t even have a wire on the harness for that pin, so it won’t affect it at all. 1 Link to comment Share on other sites More sharing options...
Sjackson2 Posted February 16, 2019 Author Share Posted February 16, 2019 Perfect!! Thanks a ton. Link to comment Share on other sites More sharing options...
