PrecisionX Posted January 15, 2019 Share Posted January 15, 2019 My heater went nuts on my 01 Pathfinder and the switch would only be on full blast or not at all and now it’s dead. I need either a wiring harness or switch wiring that connects to it. Any help finding this would be great. I believe it’s called a blower motor speed switch pigtail? The connector. Thank you! Link to comment Share on other sites More sharing options...
PathyDude17 Posted January 15, 2019 Share Posted January 15, 2019 Junkyard is your best bet 1 Link to comment Share on other sites More sharing options...
adamzan Posted January 15, 2019 Share Posted January 15, 2019 Sounds like you need a blower motor resistor. Link to comment Share on other sites More sharing options...
PrecisionX Posted January 15, 2019 Author Share Posted January 15, 2019 No luck at junkyards. Blower motor resister isn’t it. Link to comment Share on other sites More sharing options...
PathyDude17 Posted January 15, 2019 Share Posted January 15, 2019 There’s a fan control amp that can go bad on the digital climate control units, I’ve replaced that on mine before. If you have that, you could give that a shot along with your other idea Link to comment Share on other sites More sharing options...
PrecisionX Posted January 15, 2019 Author Share Posted January 15, 2019 I have manual heat it is a 2001 SE model and what happened was the controller behind the switch melted Which is a six point connector behind the switch I believe but I don’t know what the actual part is called because it is technically not a part that is available by it self Link to comment Share on other sites More sharing options...
PathyDude17 Posted January 15, 2019 Share Posted January 15, 2019 If its a wiring harness/adapter, good luck. I tried to find one online and at an auto parts store to no avail. Link to comment Share on other sites More sharing options...
