Guest jared.t.shields Posted December 6, 2018 Share Posted December 6, 2018 Ok I have a 3” lift on my Qx4 and would like some bigger tires. Should I go 265/70/17 or 275/70/17? Also know I’m probs gonna have to cut some of the bumpers. But any advice would be much appreciated. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Ole_Rosie_R50 Posted December 6, 2018 Share Posted December 6, 2018 I have no clue what tire size you should get but I totally recommend the Falken Wildpeak at/w3Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
joshrichard Posted December 6, 2018 Share Posted December 6, 2018 275 are 33’s right? I went with 265 because I know with 33’s there’s a lot of cutting that you need to do. There’s a thread on here about fitting 33’s. I would search it on goggle and then put npora after Link to comment Share on other sites More sharing options...
Tomek Posted December 7, 2018 Share Posted December 7, 2018 to search a particular site with google type "33 site: http://www.nissanpathfinders.net" 1 Link to comment Share on other sites More sharing options...
hawairish Posted December 7, 2018 Share Posted December 7, 2018 On 12/6/2018 at 8:15 AM, joshrichard said: 275 are 33’s right? I went with 265 because I know with 33’s there’s a lot of cutting that you need to do. There’s a thread on here about fitting 33’s. I would search it on goggle and then put npora after Neither of those are 33’s, though 275 and 265 by themselves don’t tell you anything about the diameter, only width. The need to trim is also dependent on the wheel offset. 1 Link to comment Share on other sites More sharing options...
herotrooper Posted December 12, 2018 Share Posted December 12, 2018 You want the second number. For instance, 75 is close to 32” at 31.6” I believe. You should probably just look for 33” tires. Link to comment Share on other sites More sharing options...
PathyDude17 Posted December 12, 2018 Share Posted December 12, 2018 This is a good resource https://tiresize.com/chart/ 1 Link to comment Share on other sites More sharing options...
hawairish Posted December 12, 2018 Share Posted December 12, 2018 15 hours ago, herotrooper said: You want the second number. For instance, 75 is close to 32” at 31.6” I believe. You should probably just look for 33” tires. You need all numbers, though, to determine diameter; 265/75-16 and 265/75-17 differ by 1". 8 hours ago, PathyDude17 said: This is a good resource https://tiresize.com/chart/ They're a great resource. Specifically check out their tire calculators: https://tiresize.com/calculator/ Link to comment Share on other sites More sharing options...
