joshrichard Posted December 17, 2018 Author Share Posted December 17, 2018 Nice rig! Had to replace the fuel filler neck and the lines too, alongside new headlights and future spark plugs. Have you settled on any aftermarket lights?https://www.headlightsdepot.com/99-04-nissan-pathfinder-headlight-front-left-driver-right-passenger-side.html?SID=3bd8817b6d344992e3cf967f6f56247f&gclid=Cj0KCQiAgMPgBRDDARIsAOh3uyJt-zl8mF2-V5DZHB0jlubrUe0AM1Q6mSTQUhB-QK5IgwtFmKXi4SAaAneaEALw_wcBI’m thinking about these and pairing them up with some plug and play LED’s Link to comment Share on other sites More sharing options...
Guest Posted December 18, 2018 Share Posted December 18, 2018 6 hours ago, joshrichard said: https://www.headlightsdepot.com/99-04-nissan-pathfinder-headlight-front-left-driver-right-passenger-side.html?SID=3bd8817b6d344992e3cf967f6f56247f&gclid=Cj0KCQiAgMPgBRDDARIsAOh3uyJt-zl8mF2-V5DZHB0jlubrUe0AM1Q6mSTQUhB-QK5IgwtFmKXi4SAaAneaEALw_wcB I’m thinking about these and pairing them up with some plug and play LED’s I strongly advise against those. I purchased them and the beam pattern in very inconsistent. If there is nothing wrong with the oem assemblies I recommend keeping them. If they are yellow, then replace with oem used. Link to comment Share on other sites More sharing options...
joshrichard Posted December 18, 2018 Author Share Posted December 18, 2018 I strongly advise against those. I purchased them and the beam pattern in very inconsistent. If there is nothing wrong with the oem assemblies I recommend keeping them. If they are yellow, then replace with oem used.Noted! Thanks Link to comment Share on other sites More sharing options...
joshrichard Posted December 18, 2018 Author Share Posted December 18, 2018 Wow it looks better than I thought it would! 3 Link to comment Share on other sites More sharing options...
RainGoat Posted December 19, 2018 Share Posted December 19, 2018 What did you decide for the final lift? BTW, post that outside shot from IG, it shows the truck really well. Link to comment Share on other sites More sharing options...
joshrichard Posted December 19, 2018 Author Share Posted December 19, 2018 What did you decide for the final lift? BTW, post that outside shot from IG, it shows the truck really well. I decided to go with the 1.5 spacer in the front, then AC springs in the rear with Bilstein 5100’s. I also got camber bolts in the front with manual hubs and a 1/4 spacer in the front because the tires weren’t comfortably fitting in there for me. Then all of that are sitting on some 260/70/17 Rated E Nitto Crosstek’s that I scored for free. Had to do a tiny amount of replacement fitting for the splash guard but took about 5 minutes. I think it looks awesome in real life! 4 Link to comment Share on other sites More sharing options...
fleurys Posted December 19, 2018 Share Posted December 19, 2018 Very nice! I just love the black ones !.. 1 Link to comment Share on other sites More sharing options...
joshrichard Posted December 19, 2018 Author Share Posted December 19, 2018 Thanks! Link to comment Share on other sites More sharing options...
PathyDude17 Posted December 19, 2018 Share Posted December 19, 2018 Are your tires 265/70/17? Link to comment Share on other sites More sharing options...
joshrichard Posted December 20, 2018 Author Share Posted December 20, 2018 Yes Link to comment Share on other sites More sharing options...
03TroutFinder Posted December 20, 2018 Share Posted December 20, 2018 Nice ride man. Very clean!Love those stock wheels too. Good job.Sent from my SAMSUNG-SM-G930A using Tapatalk 1 Link to comment Share on other sites More sharing options...
joshrichard Posted December 20, 2018 Author Share Posted December 20, 2018 Thanks I love these rims as well! 1 Link to comment Share on other sites More sharing options...
joshrichard Posted December 20, 2018 Author Share Posted December 20, 2018 Truck did awesome and felt great after a little trial run!! 3 Link to comment Share on other sites More sharing options...
mjotrainbrain Posted December 20, 2018 Share Posted December 20, 2018 Looks really good! Glad to hear you're happy with the results. 1 Link to comment Share on other sites More sharing options...
PathyDude17 Posted December 20, 2018 Share Posted December 20, 2018 The black looks so good all cleaned up 1 Link to comment Share on other sites More sharing options...
joshrichard Posted January 7, 2019 Author Share Posted January 7, 2019 Loaded the bikes and some people up and went for a ride yesterday, the weather was amazing. After riding on the AC springs in the rear for a few weeks I love how they ride. They are definitely very stiff but I enjoy it, especially when loaded up the springs sat level, and that was with the bike rack, 4 bikes, and 4 people in the truck. Really enjoying the better handling as well! 4 Link to comment Share on other sites More sharing options...
joshrichard Posted January 14, 2019 Author Share Posted January 14, 2019 Squeaking in the back during acceleration, Sway Bar bushings or lower trailing arm bushings? It used to do it only when it rained but since the lift it does it everytime I hit a bump or everytime I accelerate quickly which makes me think both. Should I replace the sway bar bushings in the rear? I read people using polyeurathane bushings? Link to comment Share on other sites More sharing options...
02_Pathy Posted January 14, 2019 Share Posted January 14, 2019 I replaced my sway bar bushings and the squeak went away for me. I also replaced my lower trailing arms as well but I never really got any noise from them prior to replacing them. Link to comment Share on other sites More sharing options...
joshrichard Posted January 14, 2019 Author Share Posted January 14, 2019 I replaced my sway bar bushings and the squeak went away for me. I also replaced my lower trailing arms as well but I never really got any noise from them prior to replacing them. My trailing arms are pretty donezo, any recommendations for them? Should I replace the sway bar bushings with poly bushings? 1 Link to comment Share on other sites More sharing options...
RainGoat Posted January 14, 2019 Share Posted January 14, 2019 I replaced my sway bar bushings and the squeak went away for me. I also replaced my lower trailing arms as well but I never really got any noise from them prior to replacing them. AC has the poly sway bar bushings. I think there may be sway bar links with bushings back there as well. With regard to rear upper & lower control arms, be aware that this is something[mention=37543]TowndawgR50[/mention] is starting to produce. See@Jax99 build thread. 1 Link to comment Share on other sites More sharing options...
joshrichard Posted January 14, 2019 Author Share Posted January 14, 2019 Interesting... how would someone get a hold of those? Link to comment Share on other sites More sharing options...
RainGoat Posted January 15, 2019 Share Posted January 15, 2019 PM@TowndawgR50 He &@hawairish are ramping up an aftermarket business for R50s. I’m not sure they’re up to full time production yet but you can put yourself on their list & start a conversation. I believe this is just the beginning of good things to come (SFD kits, bumper brackets, sliders or slider adapters, maybe eventually MOLLE panels & skids. You may decide against it now or later, or it may be just what you want. I already have a heavy duty set but I just figured better to be in the know & make a conscious decision rather than find out about it later. Link to comment Share on other sites More sharing options...
02_Pathy Posted January 15, 2019 Share Posted January 15, 2019 16 hours ago, joshrichard said: My trailing arms are pretty donezo, any recommendations for them? Should I replace the sway bar bushings with poly bushings? I just replaced the whole trailing arms that I got from RockAuto, I didn't feel like pressing out the old bushings but I kind of regret not putting poly bushings in. Now that @TowndawgR50 and @hawairish are making parts for our rigs I might upgrade to their trailing arms. Also if you use poly bushings they could squeak more if they're not lubed with grease so just FYI on that. The Moog rubber bushings I used are quiet until they go bad again 2 Link to comment Share on other sites More sharing options...
joshrichard Posted January 15, 2019 Author Share Posted January 15, 2019 better to be in the know & make a conscious decision rather than find out about it later.Yes, thank you. Would definitely rather go that route. I know how meticulous those two are with their rigs 1 1 Link to comment Share on other sites More sharing options...
joshrichard Posted January 20, 2019 Author Share Posted January 20, 2019 Saw these beauties for sale in my town 1 Link to comment Share on other sites More sharing options...
