Wacky_Pathy Posted November 14, 2018 Share Posted November 14, 2018 I'm in need of a new idler arm at some point this month. I've noticed it getting worse gradually, more play in steering wheel, alignment sucks ass, and I moved the actual wheel back and forth yesterday and that arm moved up and down like I've never seen before. Whats a good company to go with? Should I get a moog idler arm or get a stock one and a brace from AC? Link to comment Share on other sites More sharing options...
SpecialWarr Posted November 14, 2018 Share Posted November 14, 2018 I suspect that the brass bushing in the arm is toast! I think you might be able to just throw on a stock new one from one of our fine vendors and be good to go. If you off-road a lot I would get the AC brace, but mine has taken a beating and is still good without the brace (at least... as far as I can tell!!) I would tell you to get the Beck/ Arnely because it seems that it is the only one with a grease port. None of the others seem to have one! https://www.rockauto.com/en/moreinfo.php?pk=493175&cc=1211926&jsn=525 1 Link to comment Share on other sites More sharing options...
Wacky_Pathy Posted November 14, 2018 Author Share Posted November 14, 2018 Thanks for your help buddy. I may just do a brace with it as well cause why not. Doesn't hurt 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted November 15, 2018 Share Posted November 15, 2018 You can get aftermarket brass bushings to rebuild a wallered idler. OE is plastic. I've got a 555 (think it was in an AC Delco box) on mine, with a homemade brace. Link to comment Share on other sites More sharing options...
adamzan Posted November 16, 2018 Share Posted November 16, 2018 The 555/Ac delco professional one is the best aftermarket. Otherwise just rebuild your stock one with the bronze bushings. The stock ones are NOT brass, they're nylon/plastic. Kind of like what timing chain guides are made of. Link to comment Share on other sites More sharing options...
adamzan Posted November 16, 2018 Share Posted November 16, 2018 http://bandit4x4.com/4x4-truck-parts/steering-parts/oem-stock-idler-arm-bushings/ 1 Link to comment Share on other sites More sharing options...
