JPMAT0S Posted November 9, 2018 Share Posted November 9, 2018 I need help to find the stock spring height for the rear of a 2000 pathfinder se.i want to go atleast 1 inch higher than stock.im not trying to go higher than that.i only mainly want it for a bit better towing , suspension,and asthetics with stock rims and tires. I just redid my front suspension so I’ll probably just use a 1 inch spacer for the front but i greatly need new springs for the rear aswell as shock absorbers because with my friend weighing at 250lbs and siting in my trunk the the rear tires are touching the wheel wells and even going over bumps while off-roading too so im constantly bottoming out and hitting the bumps stop in the rear which is the only thing saving my frame from cracking Link to comment Share on other sites More sharing options...
JPMAT0S Posted November 9, 2018 Author Share Posted November 9, 2018 I saw i can use land rover spring im just not sure which ones aswell im not trying to break the bank Link to comment Share on other sites More sharing options...
joshrichard Posted November 9, 2018 Share Posted November 9, 2018 I saw i can use land rover spring im just not sure which ones aswell im not trying to break the bankI think the smallest one they have found was 2.5 inches and was the NRC9446’s IIRC Link to comment Share on other sites More sharing options...
joshrichard Posted November 9, 2018 Share Posted November 9, 2018 Old Man Emu (OME) has a 1.75 lift for the rear Link to comment Share on other sites More sharing options...
JPMAT0S Posted November 14, 2018 Author Share Posted November 14, 2018 On 11/9/2018 at 10:55 AM, joshrichard said: Old Man Emu (OME) has a 1.75 lift for the rear What about a flat 2 inch lift Link to comment Share on other sites More sharing options...
01Pathmaker Posted November 15, 2018 Share Posted November 15, 2018 AC is the only 2" spring lift available 1 Link to comment Share on other sites More sharing options...
RainGoat Posted November 15, 2018 Share Posted November 15, 2018 The OMEs are probably the best ride quality but unfortunately only come in medium duty for the rear (heavy duty available for the front) & are expensive. The LR Defender springs for the rear are getting great reviews - ride quality sounds on par with the OME but less expensive & with higher spring rates if desired. AC is reliably 2” but pretty harsh by all reports. As an FYI, the LR Springs from LR direct are about $80-85 total (& $50 of that is shipping) from LR direct. I ordered mine Friday & they were on my doorstep in Seattle on Monday. Here is the LR info summarized to date:Land Rover Defender 90 Spring Summaryhttp://www.red90.ca/rovers/springinfo.html5” Inner Diameter NRC9446 +2.5-3” (15Spring Ht) 0.5-1" rake c 2 front spacers 175# Spring Rate LR 90 Defender-Front Driver (0.5" longer than passenger) NRC9447 +2-2.5" (Micah got 4") 175# Spring Rate LR 90 Defender-Front Passenger NRC9448 +4(Perfect c 4"SFD), cut one coil=3" 225# Spring Rate Blue”/Red LR 90 Defender-RearRH 110 & 130 Heavy Duty-Front RH $80 Delivered from UK $84.49($32.92+$51.57) from NRC9449 +2-2.5" (same Height as NRC9447) 225# Spring Rate (heavier Load than NRC9447) 1badqx4 9446: neilca(35"F/36"R c 31"tireMid Fender Ht) 9447: 19pathfinder99, MichaelAndrews,micahfelker(37-37.5" c 31"tire, MD OME Springs, F=HD OME), thehillboys (Bilstein 1525 shocks)LR - 34 1/4" to 38 1/2" settled to 37.5" net 3 1/4"RR-33 3/4" to 38" settled to 37.5" net 3 3/4"Front 35” c Moog OEM Springs, KYB Struts & 1 1/2" spacerLF - 32 1/2" to 35 net 2 1/2" (slightly uneven shop floor)LR- 32" to 35 net 3"Rake 2.5” 9448: hawairish(3”SFD), TowndawgR50(4”SFD), Bax03SE(37"F/38"R c 33"tire Mid Fender Ht-1 coil cut), drewp29, Jax99(3”SFD) 9449: 03Troutfinder (36.5" from 34", same ht as OEM Spring+2”spacer) Order from LRdirectBrands-few reviews on LR forums say Brit Part (c8) springs held up better than OEM Land Rover against sagging Link to comment Share on other sites More sharing options...
