IRONFIST Posted November 18, 2018 Author Share Posted November 18, 2018 On 11/10/2018 at 5:48 PM, onespiritbrain said: I’ve also heard about people reaching those bolts by going thru an access hole in the floor near the gear shifter. It should be there even though you don’t have a floor lever for the transfercase. That's really clever, I'm going to see if that works. At this point I probably don't need to go that route as I've done enough ripping apart of the engine to pretty much reach everything, but that's an interesting idea and now I need to know if it would work to put the engine in. Link to comment Share on other sites More sharing options...
Valeo Posted May 4, 2020 Share Posted May 4, 2020 Hey Ironfist: I am new to this forum but I have a similar question that you raised. I have a 2001 Pathy automatic (RE4R01A) 4WD with the electronic shift for the 4WD on the adapter case. I am told that a RE4R01A 4WD with the manual shift for the 4WD on the adapter case is interchangeable. I mean that the transmission case from the manual shift can be switched onto the adaptor case with the electronic shift. Is this what you were getting at In your post. By the way both tranny are from 2001 LE models with the 3.5L. Thanks, any help would be great. Link to comment Share on other sites More sharing options...
