ramdala Posted September 25, 2018 Share Posted September 25, 2018 Dear All, Long time without posting.... Well, I want to share the new tpms system I've installed on the pathy. The previous one had a non replaceable battery on the sensors, so when they all finally died all the sensors went useless. Here is the previous installation link: TPMS V1.0 I found a tmps system, that can be mounted and have the dimensions of the switches that are not used on the dashboard... and the batteries of the sensors can be repleaced! take a look: 1 Link to comment Share on other sites More sharing options...
RainGoat Posted September 25, 2018 Share Posted September 25, 2018 Dear All, Long time without posting.... Well, I want to share the new tpms system I've installed on the pathy. The previous one had a non replaceable battery on the sensors, so when they all finally died all the sensors went useless. I found a tmps system, that can be mounted and have the dimensions of the switches that are not used on the dashboard... and the batteries of the sensors can be repleaced!More info please? Link to comment Share on other sites More sharing options...
ramdala Posted September 25, 2018 Author Share Posted September 25, 2018 31 minutes ago, RainGoat said: More info please? Sure, the install it is about the same as the previous one I had. You only have to cut a small part of the slot and the display fits nicely and keep in place just with pressure. I glued the display frame to the center console becasuse the "hooks" on it are designed for newer nissans (?) and I wanted to be sure that the display wont go inside. I haven't buyed mine from amazon but here you can find it: https://www.amazon.com/HUAHAT-HuaHat-Monitoring-Customized-Temperature/dp/B073P3VMPX/ref=sr_1_3?s=automotive&ie=UTF8&qid=1537885846&sr=1-3&keywords=careud%2Bu912&th=1 Link to comment Share on other sites More sharing options...
Inyourface1650 Posted September 27, 2018 Share Posted September 27, 2018 This is pretty cool. Not expensive either. $100!? So far my Pathfinder has front air bags, side airbags, AWD, and leather heated seats. It does not have , SiruisXM, VDC, or TPMS....but otherwise has everything a modern vehicle has...and I spent $1000 on it. I may add this and a new Stereo and call it good. Link to comment Share on other sites More sharing options...
Guest Posted September 27, 2018 Share Posted September 27, 2018 Sure, the install it is about the same as the previous one I had. You only have to cut a small part of the slot and the display fits nicely and keep in place just with pressure. I glued the display frame to the center console becasuse the "hooks" on it are designed for newer nissans (?) and I wanted to be sure that the display wont go inside. I haven't buyed mine from amazon but here you can find it:https://www.amazon.com/HUAHAT-HuaHat-Monitoring-Customized-Temperature/dp/B073P3VMPX/ref=sr_1_3?s=automotive&ie=UTF8&qid=1537885846&sr=1-3&keywords=careud%2Bu912&th=1Estos me gustan más que los sensores de fábrica. Como funcionan? Los sensores quedan por dentro de la llanta? Es ajustable la alerta de presión? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ramdala Posted September 28, 2018 Author Share Posted September 28, 2018 21 hours ago, Astrorami said: Estos me gustan más que los sensores de fábrica. Como funcionan? Los sensores quedan por dentro de la llanta? Es ajustable la alerta de presión? Sent from my iPhone using Tapatalk Funcionan igual que los de fabrica, con un sensor en el interior de la llanta. Si, la alerta se puede ajustar. Link to comment Share on other sites More sharing options...
