32x11.50R15
Jimmie
On my 95 Se I have 31x10.50r15 tires that needs replacing on lego rims. I would like to go to 32x10.50r15, with stock height or 2 inch lift would I need to trim the flares ? Jim
If you are putting a 2" lift on your ride, you should be able to put 32" under it with no problems. You might even be able to go to 33"x10.50 which overall is a more common tire and save you some money. I personally want to level out my 95 by raising the front or lowering the rear. I have the same set as you do currently 31x10.50r with the Lego wheels.
