k9sar
Window limit?
Drivers side window, when using auto-up, will close completely then open about 3 inches.  I've run across mention that this is a safety feature (so you don't decapitate your cat) and that somehow the window motor has 'forgotten' the upper limit or travel.  Does anyone know if these trucks (2005 SE) have the limit reset button on the motor assembly or if the limit is reset through some sort of key/button dance?
here you go.. (You will need to remove the door panel.then...
Edited by fleurys
yea, saw that but also ran across mention of there being a procedure if there is not a reset switch on the motor.  I'll admit that I got a little lazy on this and did not crawl through the FSM to see of the R51 pathy take the with or without motor assembly.  I had not done any work (replace glass etc) or left the battery disconnected for a lengthy time that I can recall so I was hoping that the limit got screwed up accidentally by some sequence of holding the button too long, etc... otherwise it may be a mechanical failure of the switch itself.  For me, it's only a little bit aggravating but the wife keeps calling me when she takes the truck and can't get the window to stay up.  :)
