Danallen95 Posted June 8, 2018 Share Posted June 8, 2018 I have an le without the factory flares Anybody have luck finding aftermarket ones ? Thanks Link to comment Share on other sites More sharing options...
ferrariowner123 Posted June 9, 2018 Share Posted June 9, 2018 I've heard XJ flares fit, but have seen them actually installed before. Maybe you can pick up a stock and just if the concept is even possible? -Kyle Link to comment Share on other sites More sharing options...
AlabamaDan Posted June 10, 2018 Share Posted June 10, 2018 Maybe pull the OE's off a QX4. Link to comment Share on other sites More sharing options...
ferrariowner123 Posted June 10, 2018 Share Posted June 10, 2018 Maybe pull the OE's off a QX4. You'd have to pull the entire kit to get everything to match. the bumpers and flares are molded together. -Kyle 1 Link to comment Share on other sites More sharing options...
mjotrainbrain Posted June 10, 2018 Share Posted June 10, 2018 You'd have to pull the entire kit to get everything to match. the bumpers and flares are molded together. -Kyle Yup, it's a drawback in my opinion. Not only that, but the rear flares tie into the door molding, so you have to either keep the matching plastic wrapping all the way around the vehicle or ditch all of it. That being said, it does look good, especially if you trim about an inch out of the flares, it gives it a more aggressive look by removing the inward curve. Not sure if the mounting holes for the QX4 flares will match the Pathfinder flares, but it may be worth looking into, they're the fattest flares that were available for the R50. Link to comment Share on other sites More sharing options...
