snowboard419 Posted May 24, 2020 Author Share Posted May 24, 2020 On 5/14/2020 at 2:27 PM, 2milehi said: How is the engine holding together? Still pounding on it. I turned it down quite a bit as it's my only vehicle at the moment. Added a catalytic converter to help with the raw fuel smell. But she is doing well. Link to comment Share on other sites More sharing options...
silverton Posted June 12, 2020 Share Posted June 12, 2020 when you exceed 80% duty cycle, you need bigger injectors. running them so close to 100% is begging them to fail. Link to comment Share on other sites More sharing options...
snowboard419 Posted June 13, 2020 Author Share Posted June 13, 2020 On 6/11/2020 at 7:37 PM, silverton said: when you exceed 80% duty cycle, you need bigger injectors. running them so close to 100% is begging them to fail. I only ran them that hard for a short time before turning the tune down for just that reason. But I have a box of goodies in the garage that should eliminate that problem. Project is still in the works but should be coming together in the coming weeks. Link to comment Share on other sites More sharing options...
