E85 in the 95 Turbo, let's see what happens.
On 5/14/2020 at 2:27 PM, 2milehi said:
How is the engine holding together?
Still pounding on it. I turned it down quite a bit as it's my only vehicle at the moment. Added a catalytic converter to help with the raw fuel smell. But she is doing well.
  • 3 weeks later...
On 6/11/2020 at 7:37 PM, silverton said:
when you exceed 80% duty cycle, you need bigger injectors. running them so close to 100% is begging them to fail.
I only ran them that hard for a short time before turning the tune down for just that reason. But I have a box of goodies in the garage that should eliminate that problem. Project is still in the works but should be coming together in the coming weeks.
