Slartibartfast Posted December 17, 2018 Share Posted December 17, 2018 Good work getting the engine back together! Fourth is overdrive. Link to comment Share on other sites More sharing options...
Sbrowning0723 Posted December 23, 2018 Author Share Posted December 23, 2018 (edited) On 12/17/2018 at 2:35 AM, Slartibartfast said: Good work getting the engine back together! Fourth is overdrive. Thanks. My first time ever having taken an engine down that far. So I'm thinking my transmission has either dropped a gear or it's damaged internally some other way. Its hitting the correct shift points from d1-d3. But she's still really high on the rpms going freeway speeds. Also is there any difference in the trans itself from a 2wd model to a 4wd model? Also hopefully this link will work. These are the pics of my Speedo doing freeway speeds with and without overdrive on. https://m.facebook.com/story.php?story_fbid=2018109721601775&id=100002083014107 Edited December 23, 2018 by Sbrowning0723 Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted December 30, 2018 Share Posted December 30, 2018 Check your AT oil temp sensor and wiring If it doesn't warm up or senses it is warmed up, it will not shift into overdrive.....memory is hazy but it sounds logical at the moment. Also is the OD switch hooked up? I am not sure if it disconnected will display or not on the instrument cluster. Are you able to read any codes from the TCU? I have yet to be able to get any codes from my TCU through diagnostics. Link to comment Share on other sites More sharing options...
adamzan Posted January 1, 2019 Share Posted January 1, 2019 Does it start okay in park and neutral? On mine the neutral safety switch failed and it wouldn’t go into OD or start in N. The truck also thought it was in P so the computer didn’t know what to do. Link to comment Share on other sites More sharing options...
Sbrowning0723 Posted January 3, 2019 Author Share Posted January 3, 2019 Starts just fine in neutral and park. And it's not throwing any codes. Link to comment Share on other sites More sharing options...
