98 pathfinder restoration
Decided i cant let this thing go to the junk yard because I know theres still years of enjoyment left in it. Motors shot as is the Trans so step 1 will be removing both. Have been searching for hours trying to find a how to on these matters but cant find anything does anybody know of one? Thanks for all the help im sure i will get over the next few months
The Chilton & Haynes are good, but designed to help the shadetree mechanic, whereas the FSM is much more thorough, designed to walk professional techs through every diagnostic and repair procedure on the vehicle.
at.pdf 05-Feb-2010 17:48 8.4M
ax.pdf 05-Feb-2010 17:48 625K
br.pdf 05-Feb-2010 17:48 2.1M
bt.pdf 05-Feb-2010 17:48 1.1M
cl.pdf 05-Feb-2010 17:48 347K
ec.pdf 05-Feb-2010 17:49 13M
el.pdf 05-Feb-2010 17:49 5.5M
em.pdf 05-Feb-2010 17:49 1.8M
fe.pdf 05-Feb-2010 17:49 256K
foldout.pdf 05-Feb-2010 17:49 80K
fwd.pdf 05-Feb-2010 17:49 145K
gi.pdf 05-Feb-2010 17:49 1.4M
ha.pdf 05-Feb-2010 17:49 4.2M
idx.pdf 05-Feb-2010 17:49 397K
lc.pdf 05-Feb-2010 17:49 476K
ma.pdf 05-Feb-2010 17:49 846K
mt.pdf 05-Feb-2010 17:49 1.0M
pd.pdf 05-Feb-2010 17:49 1.7M
rs.pdf 05-Feb-2010 17:49 1.2M
sc.pdf 05-Feb-2010 17:49 366K
st.pdf 05-Feb-2010 17:49 1.0M
su.pdf 05-Feb-2010 17:49 623K
tf.pdf 05-Feb-2010 17:48 900K
Any way to decipher this nonsense.. might as well be ancient greek not trying to print the whole thing just what would be applicable
For future reference, idx.pdf is the index. It's the first one I open when I need to find a specific section for a part.
What I did was download the lot of them, then rename each one with the section name, not just the abbreviation. After you use it for a while, the abbreviations and organization start to make some amount of sense.
For some FSMs, if you download them all into a single folder and start with the fwd.pdf, you can just click around to get into the section and pages you need. Probably depends on how the FSMs were imported (i.e., scanned from book or from original CDs or other digital imports).
