Moving To New Servers!
*Temporarily On Hold Due To Time Restrictions*
Members interested in helping test the new NPORA server platform, please contact RedPath88 via PM or email for further information.
Thank you,
after AT tranny rebuld, still won't go past 2nd gear
  • Please log in to reply
7 replies to this topic
#1 OFFLINE   oldpathfinder
oldpathfinder
  • Members
  • Pip
  • 8 posts
  • Local time: 04:39 AM
  • Country:
  • Model:SE
  • Year:1997
Posted 11 February 2018 - 10:16 PM
Hope someone can help. after 250K miles, everything is going. 97 pathfinder SE 4WD has new radiator, steering bushings and repair the leak that ate the bushings, transaxle, boots, brake pedal and cruise control plastic thingys, timing belt, water pump, main engine seal, rotor and coil, tune up, brakes, tires, shocks,distributor cap and headlights. I'm sure I've forgotten something.
All repairs were done by good mechanics, except the distributor work which was redone by a good mechanic.
On road trip in ice and snow, the car was getting 10 mpg when normal is 20+. Did not realize I had lost OD until 3rd gear went. Car would rev up but not gain speed above 40. Eventually it went down to 25 mph but made it to tranny shop.  Low transmission fluid. No contamination in fluid. Rebuild transmission. There were damaged clutches. Experienced mechanic put it back together, took it for test drive and it was doing the same thing. Said in all the ones (this model nissan transmission) he's done this has never happened. Took it back to shop. Now it won't start. Nothing. No click. He tried disconnect the battery, no go.
Any suggestions?
#2 OFFLINE   CNAM
CNAM
    And if you don't know, now you know....
  • Members
  • PipPipPipPipPip
  • 1,637 posts
  • Local time: 02:39 AM
  • Country:
  • Model:SE
  • Year:2001
Posted 11 February 2018 - 11:20 PM
Did they replace the shift solenoids when the trans was rebuilt?
#3 OFFLINE   oldpathfinder
oldpathfinder
  • Topic Starter
  • Members
  • Pip
  • 8 posts
  • Country:
  • Model:SE
  • Year:1997
Posted 12 February 2018 - 11:00 AM
yes, the solenoids were changed and just double checked. No change
#4 OFFLINE   Cuong Nguyen
Cuong Nguyen
    Mr. RTI
  • Members
  • PipPipPipPipPip
  • 2,324 posts
  • Model:XE
  • Year:1993
Posted 12 February 2018 - 11:48 AM
Any suggestions?
Battery load tested?
Battery Wiring and connections clean and tight?
Starter relay? Check starter by bypassing relay.
No codes?
Sent from my SAMSUNG-SM-N920A using Tapatalk
#5 OFFLINE   oldpathfinder
oldpathfinder
  • Topic Starter
  • Members
  • Pip
  • 8 posts
  • Country:
  • Model:SE
  • Year:1997
Posted 13 February 2018 - 10:17 AM
yes, he has already checked all of the above. It starts fine if you bypass.
#6 OFFLINE   Citron
Citron
  • Members
  • PipPipPipPipPip
  • 951 posts
  • Local time: 01:39 AM
  • Country:
  • Model:SE
  • Year:1992
Posted 13 February 2018 - 08:46 PM
Bypass what? Starter selenoid, relay, ignition, park safety switch?
#7 OFFLINE   oldpathfinder
oldpathfinder
  • Topic Starter
  • Members
  • Pip
  • 8 posts
  • Country:
  • Model:SE
  • Year:1997
Posted 17 February 2018 - 11:12 AM
Found the no start problem. The starter IS bad. Just not consistently bad. Finally got it to act up. Being replaced. Never failed to start first time every time until in the shop. Go figure. Found the 3rd gear problem. Seal failure. So all is well in the land of oldpathfinder. for the time being. Thanks to all who helped.
#8 OFFLINE   mjotrainbrain
mjotrainbrain
    What's an alignment?
  • TOTM Moderator
  • PipPipPipPipPip
  • 1,002 posts
  • Local time: 05:39 AM
  • Country:
  • Model:Other/Unknown
  • Year:2002
Posted 17 February 2018 - 11:14 AM
Good to hear!  Hopefully that's the end of the issues now.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
