Moving To New Servers!
*Temporarily On Hold Due To Time Restrictions*
Members interested in helping test the new NPORA server platform, please contact RedPath88 via PM or email for further information.
Thank you,
Loud whining rises with engine RPM
  • Please log in to reply
11 replies to this topic
#1 OFFLINE   uncle.penny
uncle.penny
  • Members
  • Pip
  • 22 posts
  • Local time: 03:37 AM
  • Country:
  • Model:SE
  • Year:1995
Posted 05 February 2018 - 04:08 PM
Hi all!
2 problem posts in 1 week, I'm on a roll!
So I have a quite loud whining that rises with the engine speed as the title states, it's basically as loud as the engine itself. If I didn't know any better I'd think someone stuck on a supercharger running 15psi haha. I've noticed no driveability issues with it, but it's annoying and if it's something that could potentially become serious I'd rather take care of it now. The pitch doesn't change when I dry-steer so I don't think it's the PS pump, so in my head I've narrowed it down to either the water pump or alternator (while crossing my fingers that it's not the pump).
Anyone dealt with a whiny Path before? Is there a good trick for diagnosing it aside from using a stethoscope/long screwdriver?
#2 OFFLINE   Citron
Citron
  • Members
  • PipPipPipPipPip
  • 951 posts
  • Local time: 01:37 AM
  • Country:
  • Model:SE
  • Year:1992
Posted 05 February 2018 - 05:47 PM
Pull the accessory belts off and spin the pulleys by hand. It is probably bad bearings on alternator, idle pulley, etc.
#3 OFFLINE   OH6PILOT
OH6PILOT
  • Members
  • PipPipPip
  • 156 posts
  • Country:
  • Model:XE
  • Year:1995
Posted 05 February 2018 - 06:22 PM
I second that motion.
#4 OFFLINE   onespiritbrain
onespiritbrain
  • Members
  • PipPipPipPipPip
  • 416 posts
  • Local time: 04:37 AM
  • Country:
  • Model:LE
  • Year:1999
Posted 05 February 2018 - 07:25 PM
I have this same issue. I believe it is the turd carquest water pump I bought.. I guess it could also be the ps pump since I’m running 68 turbine oil..
I hope it’s something else on yours :)
#5 OFFLINE   uncle.penny
uncle.penny
  • Topic Starter
  • Members
  • Pip
  • 22 posts
  • Country:
  • Model:SE
  • Year:1995
Posted 07 February 2018 - 10:27 AM
Going to pull the acc. belts tonight and see if there's anything funky going on with any of the spinning components, thanks for the suggestion!
#6 OFFLINE   Zkingcyrus
Zkingcyrus
  • Members
  • Pip
  • 10 posts
  • Local time: 10:37 AM
  • Country:
  • Model:XE
  • Year:1995
Posted 07 February 2018 - 12:00 PM
It could also be a bad fan clutch. Mine spins all the time and makes a ton of noise. Cruising at a steady speed it will fade in and out in volume but always makes some noise. I thought I was the timing belt at first but it's too inconsistent.
#7 OFFLINE   uncle.penny
uncle.penny
  • Topic Starter
  • Members
  • Pip
  • 22 posts
  • Country:
  • Model:SE
  • Year:1995
Posted 09 February 2018 - 09:12 AM
I'm 99% sure it's not the fan. I used to have an '88 300ZX with the VG30E in it with a seized fan clutch so I know exactly what that sounds like haha. Made a 2 seater sports car sound like a semi truck any time you'd take off from a stop.
Haven't had the chance to check accessories yet, probably going to leave it until Sunday to try and narrow it down. I have a sneaking suspicion it's the water pump even though I'm hoping it isn't.
#8 OFFLINE   adamzan
adamzan
    Hi
  • Members
  • PipPipPipPipPip
  • 17,753 posts
  • Local time: 05:37 AM
  • Country:
  • Model:SE
  • Year:1994
Posted 09 February 2018 - 09:33 AM
I'd say its probably the alternator, or the idler pulley for the AC.
#9 OFFLINE   uncle.penny
uncle.penny
  • Topic Starter
  • Members
  • Pip
  • 22 posts
  • Country:
  • Model:SE
  • Year:1995
Posted 10 February 2018 - 02:50 PM
Which pulley is it that's dead centre between the cylinder banks at the top? Without even taking the belts off I just felt around and that pulley had quite a lot of play in it.
#10 OFFLINE   k9sar
k9sar
    Ts'i mahnu uterna ot twan ot geifur hingts uto.
  • Members
  • PipPipPipPipPip
  • 11,293 posts
  • Model:SE
  • Year:2005
Posted 10 February 2018 - 04:00 PM
Mine was a bad idler pulley, simple to replace
#11 OFFLINE   Slartibartfast
Slartibartfast
  • Members
  • PipPipPipPipPip
  • 4,696 posts
  • Local time: 02:37 AM
  • Country:
  • Model:SE
  • Year:1993
Posted 10 February 2018 - 07:35 PM
Air conditioner idler pulley. Sounds like you found your problem!
#12 OFFLINE   SquadCarPathfinder
SquadCarPathfinder
  • Members
  • Pip
  • 33 posts
  • Country:
  • Model:XE
  • Year:1995
Posted 01 March 2018 - 10:10 AM
I actually had a similar problem with one of my own accessories. I bought a belt online from Amazon and it said it would fit the A/C pulley, but after i put it on it sounded like I had installed a supercharger. Turns out that the belt was so tight the tensioner pulley in the middle was so tight i couldn't adjust it.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
