Dezervon Posted January 24, 2018 Share Posted January 24, 2018 Hey pathy fans,what happened: -5C outside, after yesterdays drive the wipers froze to the windscreen and today I switched them on too early so the linkage snapped. Checked that the wipers are connected with each other, so the fault must be with the blades(?) from the motors end. Haven´t opened it up yet to confirm, but has anyone got experience or knows if it´s easy to DIY?kind regards, Martin 1990 Nissan Terrano 2.7TD Link to comment Share on other sites More sharing options...
Dezervon Posted January 25, 2018 Author Share Posted January 25, 2018 Opened it up and nothing was broken. The rods are connected by ball joints in the center of the linkage and under pressure, the motor´s side rod end jumped out of the socket. Clipped it back in and fixed. A lot of plastic clips didn´t make it though, as they were very brittle. So heads up when removing the air intake covers. Link to comment Share on other sites More sharing options...
Slartibartfast Posted January 25, 2018 Share Posted January 25, 2018 Good to hear it was an easy fix! And yeah, those little clips holding the air grilles on are weak sauce. I gave up on mine and used black zip ties. Link to comment Share on other sites More sharing options...
adamzan Posted January 26, 2018 Share Posted January 26, 2018 You can buy the proper ones from any place that sells body shop supplies. Link to comment Share on other sites More sharing options...
