jonathanpalmer12 Posted December 21, 2017 Share Posted December 21, 2017 Hello guys i have a 1994 nissan pathfinder 4x4, well recently i went off roading and got stuck and turned out i only had 2 wheels spinning instead of 3, well it was either 1 wheel was spinning at a time but never both(front wheels not back). It has the CV axle with autolocking hubs. Any information pertaining to this would be much apperciated thanks Sent from my SM-N920T using Tapatalk Link to comment Share on other sites More sharing options...
ubertalldude Posted December 21, 2017 Share Posted December 21, 2017 you do realize you posted like 10 copies of this thread, right? you might want to double check when you post and only click the post button once if you don't have the limited slip differential, it's very possible to only have 2 wheels spinning at once. Even with the LSD you can still get spinning between the rear 2 wheels. If only 1 particular wheel ever spins up front then you may have a real issue with the auto locking hubs, but otherwise on softer stuff it's pretty well expected for only 1 front wheel to be spinning because of the open front differential. Link to comment Share on other sites More sharing options...
adamzan Posted December 21, 2017 Share Posted December 21, 2017 Yours looks like an XE, which would have open front and rear differentials. There was never a factory limited slip option for the front. Those tires don't look the best, and that ground looks soft. Link to comment Share on other sites More sharing options...
mjotrainbrain Posted December 21, 2017 Share Posted December 21, 2017 Sometimes Tapatalk and other ways to view forums mess up and it doesn't look like you're posting the thread, but you arr, hence why new people often post the same thread many times. Anyway, as others have said that sounds exactly like what happens with open differentials. I don't you have anything broken, that's just how it works when the going gets really tough. Link to comment Share on other sites More sharing options...
mjotrainbrain Posted December 21, 2017 Share Posted December 21, 2017 If you try to flex the suspension really far eventually you'll just have the two tires with the least pressure on the ground spinning and you'll stop going forward, same reason as this situation is happening. Link to comment Share on other sites More sharing options...
