Thatoneguy Posted December 10, 2017 Share Posted December 10, 2017 I have a 89 pathfinder SE. One day while driving it lost power for a quick second almost like a hiccup, once i came off the gas it would not accelerate and when it would, it would putt, almost like a machine gun, ive changed MAF, TPS, O2 sensor, engine coolant temp sensor, and its worse, now it idles like an old truck as if it wants to die, when i got it last year i changed, fuel filter, spark plugs, air filter. When i drive now its like a rodeo, it stops and goes, stops and goes but when it goes its a hard kick. Any idea? Link to comment Share on other sites More sharing options...
adamzan Posted December 13, 2017 Share Posted December 13, 2017 Check the timing? 1 Link to comment Share on other sites More sharing options...
Thatoneguy Posted December 15, 2017 Author Share Posted December 15, 2017 It seems like me and Leo94 have the exact same issue with fuel in oil and smoke when it runs and all that, going to try a few things then go ahead and check timing, thanks for the reply! Link to comment Share on other sites More sharing options...
Thatoneguy Posted December 15, 2017 Author Share Posted December 15, 2017 http://www.nissanpathfinders.net/forum/topic/33854-rough-idle-missfire-and-smoke/?p=636237 Link to comment Share on other sites More sharing options...
Slartibartfast Posted December 15, 2017 Share Posted December 15, 2017 Fuel in oil and smoke when it runs sounds like a leaky injector to me. Or the ECU is richening the mixture to absurd lengths. I don't know the TBI as well but I'd start by doing the ECU self-test on the oxygen sensor and checking the temp sensor to see if it's in spec. Link to comment Share on other sites More sharing options...
