gaps18 Posted November 8, 2017 Share Posted November 8, 2017 Hello, I just bought a 2001 QX4 with 98,300 miles on it. Per the carfax it has 2 previous owners and zero accidents. I'm looking to put some new tires and possibly new wheels on it too. It currently has 245/65/17s on it but I'm looking to put bigger tires on it, I'm leaning towards the BFG KO2. What is the biggest size I can go with before I have to put spacers on? I dont mind a little trimming and at the most I would do would be 2" spacers. Thanks for all of the info on here! Link to comment Share on other sites More sharing options...
gaps18 Posted November 8, 2017 Author Share Posted November 8, 2017 Would a set of 255/75/17 BFG Mud Terrains fit with some trimming? The reason I ask is I found a set of 5 brand new Jeep Rubicon takeoff wheels and tires for $950. I noticed that the wheels are for 5 lug and the QX4 is a 6 lug.....would wheel adapters work and would this size fit with trimming? Thanks for any info!! Link to comment Share on other sites More sharing options...
mjotrainbrain Posted November 8, 2017 Share Posted November 8, 2017 That's about a 32" tire. It would only fit with more offset than stock (not sure what Jeep wheels and adapters would do for you, although I don't recommend adapters/spacers personally anyway) and either trimming or a lift. I have 32x11.50x15 on my 2002 with very little trimming with about a 2.5" lift (what you would get with 2" spacers). Stock you can fit a 31" tire. Anything bigger will get into the fenders, and more importantly, won't clear the struts up front. 1 Link to comment Share on other sites More sharing options...
teixeira Posted November 8, 2017 Share Posted November 8, 2017 Link to comment Share on other sites More sharing options...
fleurys Posted November 8, 2017 Share Posted November 8, 2017 Welcome ! Link to comment Share on other sites More sharing options...
micahfelker Posted November 9, 2017 Share Posted November 9, 2017 (edited) Would a set of 255/75/17 BFG Mud Terrains fit with some trimming? The reason I ask is I found a set of 5 brand new Jeep Rubicon takeoff wheels and tires for $950. I noticed that the wheels are for 5 lug and the QX4 is a 6 lug.....would wheel adapters work and would this size fit with trimming? Thanks for any info!! I replied this already to your comment in my thread before I saw this, so I'll say the same thing here. Running those Jeep wheels would absolutely not be worth the headache of doing a 5 lug conversion, and I wouldn't trust lug pattern changing spacers. You'd be better off getting a cheap set of wheels like these paired with a set of 265/70r16 tires https://www.amazon.c...B00DJ654BW?th=1 Treadwright makes good tires for a really good price, if you're looking to stay under that $900 price range. https://www.treadwri...s/warden-w2617e With the wheels and tires I've linked you'll literally have 4 brand new tires and wheels for around $800, which is less money than those old Jeep wheels that won't even work with your rig, with the added benefit of bolting on and clearing with no problems without a lift. Edited November 9, 2017 by micahfelker 1 Link to comment Share on other sites More sharing options...
