Texasledfarmer Posted October 4, 2017 Share Posted October 4, 2017 Has anyone used a body lift, cranked torsion bars and rear lift springs all at once? I've read about lots of combinations but can't find anything on all 3 at once. I don't know if it's worth it or how bad the ride will feel. I have the body lift and I can surely crank the bars but is it worth having the springs as well? Any I'm put is much appreciated. Link to comment Share on other sites More sharing options...
OH6PILOT Posted October 9, 2017 Share Posted October 9, 2017 I currently have a 3 inch body lift, and I'm about to install a 3" suspension lift after I'm finished with the new engine replacement. I'll post more about it soon. 1 Link to comment Share on other sites More sharing options...
OH6PILOT Posted October 9, 2017 Share Posted October 9, 2017 I currently have a 3 inch body lift, and I'm about to install a 3" suspension lift after I'm finished with the new engine replacement. I'll post more about it soon. Link to comment Share on other sites More sharing options...
Bobsteriffic Posted October 9, 2017 Share Posted October 9, 2017 +1 on this thread, I'm interested in doing the same thing too. How much body lift is considered acceptable for these rigs? I just don't want to see too much frame... Link to comment Share on other sites More sharing options...
adamzan Posted October 10, 2017 Share Posted October 10, 2017 (edited) I had have a 3" body lift with the 4x4 parts 3" SL for years. I've got no complaints. If you crank the bars but don't lift the rear it will have a huge rake. Edited October 10, 2017 by adamzan Link to comment Share on other sites More sharing options...
ubertalldude Posted October 10, 2017 Share Posted October 10, 2017 I currently have a 3 inch body lift, and I'm about to install a 3" suspension lift after I'm finished with the new engine replacement. I'll post more about it soon. Do you plan on keeping the IFS setup or going with a SAS? Also in general I'll ask a simple question, would a torsion bar lift be acceptable for 1" upfront with no other modifications? I would probably put a 1" springblocker in the rear so I could stuff some 32" tires under it. Reckon if I'm gonna get beefy 31" mud tires I might as well go for 32" while I. Florida trails are muddy as all getout! Link to comment Share on other sites More sharing options...
Slartibartfast Posted October 11, 2017 Share Posted October 11, 2017 1" should be fine. IIRC you can get away with about 2" before the upper ball joints get unhappy. Link to comment Share on other sites More sharing options...
OH6PILOT Posted October 13, 2017 Share Posted October 13, 2017 Do you plan on keeping the IFS setup or going with a SAS? Also in general I'll ask a simple question, would a torsion bar lift be acceptable for 1" upfront with no other modifications? I would probably put a 1" springblocker in the rear so I could stuff some 32" tires under it. Reckon if I'm gonna get beefy 31" mud tires I might as well go for 32" while I. Florida trails are muddy as all getout! Planning on keeping the IFS. I was looking at the Calmini 3" kit, but in all honesty it's alot of money for the same thing that 4x4 parts sells for half the price. I do think that Calmini parts are probably a bit more robust, however... As for SAS...not a huge fan of it unless you're planning on going with 35's or larger. In regard to the body lift, I put on a 3" lift in about 3 hours under $100. I'm a big fan of the body lift, because it make working on the truck ALOT easier...increased clearance between the body and the frame as well as increased room to work on the engine and transmission. Plus...it looks better, IMHO. ~Hans 1 Link to comment Share on other sites More sharing options...
RF600 Posted October 20, 2017 Share Posted October 20, 2017 I have a 2" body lift, 2" suspension lift. No issue with ball joint angle. I'm running stock 31's with aftermarket wheels. That the only reason I put of the body lift. The wheels poke out more. The body lift gave the clearance so the tires didn't rub when turning. Link to comment Share on other sites More sharing options...
96pathy Posted November 2, 2017 Share Posted November 2, 2017 I have been running a 3" body lift and 3" suspension lift with 33" tires for years and have had no problems. You will need to put on an aftermarket rear track bracket to keep the rear axle aligned, longer shocks and I have put longer bolts for the upper A-arm to keep the tires better aligned. Like OH6PILOT says, makes it a lot easier to work on the truck with just the body lift. Would also recommend the 3.3 swap also. 1 Link to comment Share on other sites More sharing options...
KovemaN Posted November 6, 2017 Share Posted November 6, 2017 I ran 3+3=33" for a long time on my '91. The only time I ever had an issue was when I lost some alignment shims up front. 1 Link to comment Share on other sites More sharing options...
